TeknologikL Blog
TeknologikL
The blog's owners are constantly searching for the next device to satisfy their ever growing hunger for technology. Media junkies standing on the edge of reality, ready to take the jump.
Previous in Blog: Wrist Watches with Utility   Next in Blog: 4G Networks Are Here… Almost
9 comments
Are You Ready for Laser Televisions?
Posted September 14, 2010 12:00 AM by Jaxy
It took 5 years of development, but the laser television finally has made its debut with the help of Prysm. The technology uses repurposed Blu-ray lasers to excite red, blue, and green pixels on a screen (like old-fashioned cathode ray tubes). Prysm's "laser phosphor display" (LPD) is energy efficient, has a high resolution, and is compact. It's certain to be competitive with liquid crystal displays (LCDs) and plasma screens.
How it Works
The first generation laser televisions utilized a glass screen, the inside of which had little vertical lines of phosphor. These lines emit red, green, or blue when hit with an ultraviolet (UV) laser. There are also mirrors that scan the lasers across the screen to produce images.
Because of the set-up, the display is 14" thick. But no competitor can compare to the low power consumption. These laser televisions run at 1/4 of the power of LCD displays and at 1/10th the power of plasma screens. This could translate to serious electrical bill savings.
Is It New Technology?
Not really. According to Brad Gleeson, CEO of Vertigo Digital Displays, the LPD display is "a clever integration of existing technology." But don't expect these televisions to make a debut in your home anytime soon. These LPDs are just for commercial use at the moment. They can be found in select shopping malls, train stations, and airports.
This shouldn't be surprising. When plasma-screen televisions first appeared, they were only accessible to big commercial clients due to the steep price. Now Prysm is focusing on fixing issues on the current model and streamlining the manufacturing process.
Unlike previous rear-projection systems, the LPD does not suffer from low-brightness. It can also be stacked to make massive video walls, which cannot be done with LCD TVs, plasma TVs, or old rear-projection systems.
Do you predict LPD televisions to do well against fierce HDTV technology televisions? Why or why not?
Resources:
IEEE Spectrum – Laser TV Launches
Canada - Member - New Member
Re: Are You Ready for Laser Televisions?
09/14/2010 4:01 PM
I think this is only a stop along the way. 3D television, Holographic television, and finally the holy grail of the hologram on its own. No size restraints no monitors. Concealed hardware that makes it look like magic.
This is all conjecture, so shoot it down if it's impossible.
This is how I see it playing out. Three light sources to a single point in space, generate one pixel. Multiple lasers reflected off of spinning mirrors are used for each of the 3 light sources. Each light source uses a reference pulse source to source for real time calibration of position. This would be used for initial set up or for real time positions on moving platforms. Each light source uses three laser colours red, blue and green.
Provide the computational targeting software and projected sound output as well as sound input for interactive applications and your away to the races.
Imagine the applications.
Hava a good one.
Knowledge makes what was impossible, seem easy.
Good Answers: 69
09/15/2010 11:04 AM
Hi Elroy
G.A.
That's exactly how I envision it too, except that I'd think of lasers of three diferent invisible wavelenghts, causing interference in a single pixel, wich creates visible harmonics (so you see a "floating" color pixel). Then, the rest of your description entirely coincides with mine.
Yahlasit
09/16/2010 11:54 PM
This is all very well - both the basic wish-list and the proposed solution date back at least to the 1950s. Locally focussed scanned lasers are probably much more practical than holography, and the source could be all but invisible - but even here the problem of viewing angle remains.
What your contribution has to do the competitive position of illuminating flat-screen phosphors with a cheap UV laser is another matter. You really should have marked yourself off-topic (there's still time).
09/15/2010 1:48 PM
Learn to look at the inner "TV" screen of your mind. You won't be disappointed!! No outer technological display can hold a candle to that!
Hobbies - CNC - New Member Canada - Member - Finaly got around to it.
09/15/2010 7:17 PM
This is all very impressive and amazing. The bigger question is; will it make the garbage on TV any better? 600 channel's and nothing on!
09/15/2010 7:23 PM
You might be thinking about the Bruce Springsteen song "50 channels and nothin ON" but the effect is the same regardless of how many channels exist. It's mostly crap. What would be nice is create your own material using your imagination and laser graphics software and an RGB solid state laser projector.
09/16/2010 11:36 PM
When a CRT goes bad, a dot sometimes appears in the middle of the screen. I could address sweep times, blanking pulses, etc.; however, I'm trying to make a point.
A LASER powerful enough to energize a pixel on a screen will burn through that same screen, if it looses it's sweep drive. Just think of the implossion, the lawsuits, the happy lawyers, etc. If industry works out the bugs before the product is released, there's no problem; however, if Microsoft is used as a model, the industry will die before it gets a chance to prosper.
09/16/2010 11:43 PM
14" deep? If we are looking to future domestic use, 2" will surely be the depth limit. If we simply scale the optical arrangement, each laser will only cover 1/50th of the area. Perhaps clever optics can reduce this isue - or maybe it doesn't actually matter. Clearly there are no show-stoppers here on the technical front. The challenges will be systems integration and low-cost manufacture.
But is this a long-term solution? Personally I doubt it. Already we have high-resolution LCD displays with LED back-lighting, and lower-resolution direct phosphor LED displays (4-mm pitch is typical, but I think 1-mm is becoming available). So the logical next stage is to develope that driver matrix currently used for LCDs to the point where it will support LEDs - and then either autoassembly or in-situ LED manufacture. One major technical problem (LED electrical-to-optical efficiency) has already been overcome ...
It is possible the laser scanned phosphor display will be an interim solution for the domestic market - but I wouldn't expect it to remain at the forefront for very long.
09/16/2010 11:51 PM
Seems unlikely that any technology with moving parts is going to be successful. Mitsubishi tried to sell laser DLP sets in 2008 and they were a total flop. And why would anyone want a 14" thick TV? Can't mount that on the wall. I think the next gen sets will be LED-based (not the present LCD/LED sets).
Anonymous Poster (4); Elroy (1); Icarus (1); Laserlover (1); SSCpal (1); Yahlasit (1)
