Snakes are fun, but they can occasionally get in
trouble.
Nervous
Handlers = Nervous Snakes
Never give your snake to someone who is nervous
around or scared of snakes. If a friend insists on handling a snake – say, to
try to get over his or her fear – make sure that your friend remains calm.
Nervous people lead to nervous snakes. And you do not want your snake to get
scared and escape or bite.
Snake
Searching
Snakes are much more likely to flee than bite. As
a rule, I stay in the same room with my snakes and any new handlers so that I
can keep an eye on things. That way, if my snakes do get out of hand, I can see
where they go.
If you know exactly where the snake is hiding, you
may want to wait a short while before removing it. Give the snake a chance to
calm down a little bit. After some time, the snake is more likely to recognize
you as a help than a threat.
If your snake escapes while you're not in the
room, here are some tips to help you find it.
Stay calm – no stomping around - Snakes can
feel you walking around. They can also feel you yelling if you're loud enough. When
they're scared, snakes will move away from any strong vibrations that they feel
through the floor. Move furniture gently and have as few people in the room as
possible.
Dark places are safe places - The snake
knows that most of its predators can't see in the dark, so there's no better
place to hide! Start by looking under the furniture and then work your way up.
Begin closest to the escape location - by the cage or wherever the handler was
standing/sitting.
Remember that snakes are cold-blooded - If
it's cold in your house – or if you have wood or tile flooring – the snake will
follow instincts and seek out a heat source to stay warm. You can use this to
your advantage. If you set your snake's hide in an open space on your floor and
heat the area with a heat lamp while keeping the rest of the room cool, your
snake will eventually find it.
Keep in mind, however, that this may take a lot of
time and patience!
Food helps - If your snake hasn't eaten
recently, some food is very enticing. Do the same as above, but with a prey item
in the hide. This tactic is especially useful if you know where your snake is,
but can't quite reach it.
No space is too small - Never rule out a
hiding spot or hole that you think is too small. Unless you're dealing with a
very heavy-bodied snake, assume that if its head can fit through the space, so
can the rest of its body. Also remember that a snake skull is flexible.
Personally, I've found snakes under bookshelves,
seat cushions, heaters, and refrigerators (that one was quite a hassle!)
Snake Bites
Some snake bites happen because the snake mistakes
your finger or hand for food. Angry snakes will sometimes give a warning bite.
In either case, the snake will let go almost immediately. If the snake happens
to hold on for a little while – or even a long while, which is rare – DO NOT
pull away. You could inadvertently pull out some teeth. Just wait until the
snake lets go. Unless you taste and wiggle around like food, the snake should
let go in under a few seconds.
If a big snake bites and tries to constrict,
waiting is not an option. If it bites you on the hand or forearm, put it and
the snake's head in a tub of very cold or very hot water. This is more
difficult if the snake bites you anywhere else. In this case, you should pour
something that tastes bad or stings in its mouth. Most people recommend some
sort of alcohol. Keep this near the snake cage. Avoid anything toxic.
Snake-proofing
Snake-proofing your reptile room is a good way to
make owning a snake a much easier and more pleasant experience.
Cages - Make sure your animal's cage is
easy for you to open, close, and lock. Also make sure that the cage is set up
in a way that enables you to get your animal easily. Most importantly, make
sure that your cage-securing methods work. If you use books to weigh down the
cage top, make sure they are heavy enough. A stubborn snake can eventually
nudge open a sliding door, so make sure you have a locking mechanism. I find
that cage clamps on either end of the cage top are the best solution. They are
simple and are designed to work on many types of cages.
Furniture - You can eliminate most hiding
places in your room by making sure that your furniture either has tall legs or
no legs at all.
Doors - Put foam or a door seal or sweep at
the bottom of your door to prevent snakes from escaping into the rest of the
house.
Most
Importantly
Have fun!
This wraps up my snake series. I hope you all
enjoyed reading it as much as I enjoyed writing it.
See you around, CR4!
The Rest of the
Series
Reptiles: A Scaly Introduction
Snakes: They're All Around
Snakes: A Family Affair (Part 1)
Snakes: A Family Affair (Part 2)
Snakes: Clever and Deadly Behaviors
Snakes: Do The Locomotion (Part 1)
Snakes: Do The Locomotion (Part 2)
Snakes: A Look Inside
Snakes: Feeling Sounds And Tasting Smells
Snakes: Feeding Time! (Part 1)
Snakes: Feeding Time! (Part 2)
Snakes: Growing and Shedding
Snakes: As Pets (Part 1)
