The 'redshift-record' for the most distant object observed has just been broken again. At a redshift of z=8.6, it improves on the previous z=8.2 held by a gamma ray burst.1 This one is a feint collection of stars, possibly a cluster of galaxies, measured by the European Southern Observatory (ESO) Very Large Telescope (VLT) in Chile.2 It was first spotted by the HST in 2009 (NASA picture left), but it's redshift was not known at that time.
According to our best cosmic model, the light from the source took 13.1 billion years to reach us. This is sometimes translated as "the galaxy is 13.1 billion light years away", but that's maybe a little misleading. When the light left the galaxy, it was 'only' 3 billion light years (proper distance) from our cosmic location. Today it sits at a whopping 30 billion light years. The 13.1 billion light years may however be called "light travel distance", because if those photons had 'odometers' they would have recorded this accumulated distance relative to their local surroundings.3
The 'Cosmic Teardrop' spacetime diagram on the right shows these distances graphically. We 'are' the blue bullet at the top of the teardrop shape, which represents photons coming from two different galaxies on opposite sides from us. One of them represents the record-breaking galaxy. The hyperbolic shapes represent the spacetime paths that the two galaxies would have taken due to cosmic expansion.
The observed light from the galaxies started out at around t~0.6 Giga-year (Gy) and ~3 Gly from the origin. Due to cosmic expansion, they are presently (13.7 Gy) both at ~30 Gly proper distance. Originally, the photons that we now observe were dragged away from us by the rapid expansion of that time. As the expansion slowed down, the galaxy photons eventually started to make headway towards us (around t=4 Gy). The slopes of the hyperbolas (dt/dD) are inversely proportional to the recession rates at specific distances and times.
At the time when the photons left it, the recession rate4 of the observed galaxy was about 3.6c, then it gradually dropped to about half that rate and then slowly increased again to a present 2.2c (due to accelerated expansion). At t~4 Gy, D~6 Gly, the local recession rate where the photons then found themselves (on the teardrop, not the hyperbola), dropped to below c relative to us. Hence, the observed photons started to win over the local recession rate and began to approach us. Cool! - otherwise we would never have seen this galaxy...
Noteworthy is the fact that the inhabitants (if any) of either of the two galaxies shown cannot know about the other galaxy's existence, since light could not have traveled from the one to the other in the present cosmic lifetime. Actually, if the current accelerating expansion continues forever, light will never be able to travel between galaxies formed this far from one another.
Jorrie
Notes:
1. http://cr4.globalspec.com/blogentry/8864/Blast-From-The-Past
2. http://www.universetoday.com/76258/vlt-hubble-smash-record-for-eyeing-most-distant-galaxy/
It is just about as far as galaxy redshifts may be measurable, because during the first billion years, there must have been a light-obscuring ionized 'hydrogen-fog' that pervaded the cosmos. This happened because the first stars apparently re-ionized the hydrogen that de-ionized at some 300 thousand years after the BB. Only when the temperatures again dropped enough, the hydrogen re-ionized again, becoming properly transparent. At least, that's the theory. This measurement is an important step in the study of those early times.
3. Light travel distance is a little like the odometer of a car that records distance relative to Earth's surface, but cannot tell you how far the car has moved relative to the Sun, the Milky Way's center or the Cosmos, the latter with the Cosmic Microwave Background (CMB) as reference.
4. Recession rate relative to us is calculated from the presently observed redshift of the galaxy. Recession rates for that galaxy at earlier times are obtained from the cosmic calculator, which represents the standard cosmic expansion model accurately.
5. The plots were not run from t=0, but rather from t~0.3 million years, the time when the cosmos first became transparent to the CMB photons (also called the 'time of last scattering'). It is theorized that the first stars have formed around z~20, or t~200 million years after the BB. These galaxies (observed at z~8.6) must have formed between 200 and 600 million years.
6. The slight offset between the left and right sides of the teardrop is an artifact of round-off errors in the plotting program, not a physical effect.
