Nano Technology Blog Blog
The Nano Technology Blog is the place for conversation and discussion about materials and structured products, devices, manufacturing and commercialization, and R&D. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Did Nobel Physics Committee Get it Wrong?   Next in Blog: More Ethical Questions About Stem Cells
3 comments
Energy-Harvesting Microchips
Posted December 20, 2010 1:50 PM by Sharkles
Researchers from the University of Twente and the Institute of Technology in The Netherlands recently announced that they've manufactured a microchip that can harvest its own energy.
They placed efficient solar cells made from amorphous silicon or copper indium gallium selenide (CIGS) on top of a microchip, layering the solar cells to each layer of the chip; this process uses fewer materials, and ultimately performs better. After layering the solar, cells, the result was a sensor chip that included harvesting intelligence and an antenna for wireless communication.
Researchers found that the chip could effectively produce its own energy from its surroundings even in low light. They also noted that as long as the chip's energy was below 1milliwatt, it could even be operated indoors.
Source: New Electronics
Re: Energy-Harvesting Microchips
12/20/2010 11:29 PM
Good Answers: 7
12/21/2010 8:36 AM
Sunlight is fundamental requirement for solar power when silicon is used for p/n junction to convert photon to electron ( typical solar power generation process). When we used copper-indium-gallium selenide on the other hand needs IR light to convert IR photon (loosely used word) to electron and generate power. One can also use other combination of dipped selenide and arsenide to generate power using IR which is available 24 hours a day. Night vision less one we did based on this technology and is self supported and works in dark night taking advantage of IR light source which is now very common.
This is old technology redressed
Masyood
12/21/2010 9:52 AM
Probably absorbing all that Wifi energy over there that's killing the ash trees!
Reply Off Topic (Score 4)
gsuhas (1); Masyood (1); Rixter (1)
You might be interested in: Photovoltaic Cells, Fuel Cells, Load Cells
