Water & Wastewater Systems Blog
Water & Wastewater Systems is the place for conversation and discussion about resource management & supply, treatment, facility management & engineering, and conservation. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: The Business of Water Utility Management   Next in Blog: Algae Cleans Water, is Used for Biodiesel at RIT
9 comments
Dying Trees Investigated for Wastewater Link
Posted January 27, 2011 8:15 AM by Sharkles
What do you do when local tree populations are slowly dying? Since 2007, workers at the Wilson Bay Wastewater Treatment Facility in Jacksonville, North Carolina have noticed some trees mysteriously dying.
The plant employs a land application treatment process, which takes wastewater from the city, treats it with chemicals, and sprays the mix throughout 6,000-plus acres of city-owned land. The move to land application was considered an upward restoration trend for the plant, which had previously dumped wastewater into the New River.
When the plant expanded in 2007, workers began to notice small numbers of trees dying at the site. Experts were brought in to conduct studies, but no explanations could be determined.
Since then, the city of Jacksonville has attempted lowering the pH level of the wastewater spray and performed controlled burnings. Unfortunately, these methods also failed to result in any conclusions about the tree death.
Now that an estimated 6% of wastewater-irrigated trees have been affected, the Jacksonville city council has decided to bring in a panel of experts with varying backgrounds and resources to perform an evaluation.
Have you ever heard of issues like this related to wastewater? Do you have any hypotheses about what may be going on in Jacksonville?
Source: JDNews.com
Good Answers: 266
Re: Dying Trees Investigated for Wastewater Link
01/27/2011 9:06 AM
Over watering is a possibility. Though they can calculate and did the amount of waste water they can put on them. They have to look at how the land is going to take it in. Just because the land looks the same on the surface does not mean it is beneath it. Different soils have different absorption rates. Ground formations could be forcing it to pool causing the deaths off the trees. I looked at some of articles on it. No where did they say that these trees where planted just for this operation. If not the roots grew in relation to the natural rain fall. Some roots for water absorption others for nutrients. Those trees that are dead or dieing may not have been able to adjust. The ground around those roots for nutrients being saturated. Just as soils have different absorption rate some are harder for roots to grow in.
01/27/2011 11:41 AM
I agree. There is not enough information here to form a rational conclusion.
Are these trees newly planted for this project? If yes, what is the normal mortality rate; even in a tree nursery, there is some die off among new stock.
Engineering Fields - Instrumentation Engineering - New Member
Good Answers: 29
01/27/2011 3:19 PM
Any particular species?
What chemicals?
"Do not worry about your difficulties in Mathematics. I can assure you mine are still greater". - Albert Einstein
01/27/2011 4:04 PM
There are many possibiliies, but one thing is clear.
The next report will be equally inconclusive and non-commital. The linked new report indicates "visits to the site on Feb 7-9 and then a final report to council at 4 pm on the 9th."
This timing allows no appropriate sampling, testing or investigation other than "kick the dust and smell the breeze."
Tree death is a process that takes up to 2 years (in some species) before being evident in the above ground performance of the tree.
Possible options for tree death would include such things as
  • Wrong species for the specific location
  • Leaves sprayed in HOT weather
  • Nutrient condition of the soil
  • Chemical imbalances (Especially phosphates)
  • Copper accumulation (Assuming you use copper sulphate as part of the treatment) in the soil.
  • Waterlogging
  • old age
  • pests and insects
  • root compaction by vehicle access
  • root disturbance from "heaving" winds, especially in water bearing soil
  • Bacterial/Fungal process in the soil from not "rotating" the evaporation fields.
I'm not a tree doctor and could not necessarily diagnose any of the above DEFINITIVELY.
BTW, I am involved with our local water authority and we have significant plantations. They are "trickle" irrigated, not sprayed taking effluent and we have seen no unexplained deaths of mature trees. We also supply the same treated effluent to local farmers who irrigate pasture with it.
One question though. How big are your "wet weather detention basins"? We target 2 months of zero usage so that in prolonged wet weather we have capacity to allow the forrests to recover.
I'm interested in helping if at all possible. Stay in touch.
01/28/2011 11:56 AM
Thx very entertaining post. However, if I didn't have a degree in Soil Science I might have misinterpreted it.
Since this is in Jacksonville, they can simply go to the USDA have them come out and take a look potentially conduct some studies augmented by federal funds from USDA (NRCS) grants. The NRCS specializes in these types of problems.
Good Answers: 146
01/27/2011 8:44 PM
The article says it is Loblolly Pines that are dying, and that it started in a particularly dry year.
Pines are heavily dependent on mycorrhizae for water and nutrients. The fungal mycelium forms the "root hair" part of the tree's root system and provides both water and nutrients from the soil.
This is true of all trees to some extent, but in some cases there are exclusive or species-specific associations that are dominant, which means that fewer resources are shared with other tree species in the neighborhood, partly to cater to the tree species specific needs and tolerances. Some of the fungal symbiont species are more sensitive to extreme conditions such as drought or changes in soil pH.
For example, severe drought in my area started a die-off of the Larch (Larix laricina) that went on for several years and wiped out most of the mature trees. It seems the species-specific mycorrhizae were damaged/ died: this weakened the trees and further restricted their access to water, and bark beetles invaded as well. Luckily young trees were not affected, so they will eventually be restored.
In the case of these pines, the drought effects were probably worsened by the treated effluent. The chemicals used are not specified, but it's fairly certain that the concentration of salts in the material is high. This can create an additional physiological drought effect, as well as being prejudicial to the mycorrhizal symbiont which is intolerant. The salt concentration probably worsened the drought-related dieoff of mycelium, leaving the tree with no root hairs to absorb water or nutrients.
The picture of the dead trees also looks a lot like the work of bark beetles, although no closeup to check for sure. These die offs do happen in cycles for conifers, triggered by drought, and can't be entirely avoided. But it might be wise to avoid spraying around pines if it is worsening their chances of surviving the environmental stresses that can't be controlled.
incus opella
Good Answers: 109
01/27/2011 11:00 PM
GA to Artsmith and Justanengineer.
Both of these post have good information and may present an answer or portion of an answer. One thing I have noticed in landfill sites and in areas abutting the landfill are the premature deaths of trees. Sludge or waste water application on land may present some of the same issues that caused these tree kills on landfill sites.
Should the waste spread on the land exert a very high oxygen demand, the soils can go anaerobic and actually put the trees under severe stress. Methane migrating from landfill sites have been implicated in tree kills. A solution has been to set up some sort of aeration perimeter on landfill sites (hydrogen peroxide injection, blowing, trenching). In the case where you are spraying the waste and you are over applying it, you will create a similar condition. The site dosage levels should be monitored for nutrient metal ratios based on soils capacity. Also the waste will have a very high oxygen demand (chemical and biological). There are books on how to compute these values. Sorry I just can't think of the book I once used but I will try to get back to you or you can google for info (sludge application/metal ratios).Farmers must apply these rules to be accepted for sludge disposal but bear in mind they also till the fields several times a year and that adds aeration.
Good luck.
08/13/2011 6:47 PM
an anectdotal observation: in south Tampa there have been half a dozen 'grand' oaks felled in the past year, the first few I saw had been cut down by professionals =and after being chipped up and some largerl limbs sat around for several days before being hauled off, I assumed at first tha it was the usual disregard for the rules that some people have but noted that the insides of these trees seemed rotted from the inside and cooincidentally this is a part of Tampa that has 'reclaimed water' available, which means you have to hook up to it for your outside watering= or else pay for sewer based on entire water use,Anyway. I've been trying to simply conserve by using rainwater and a/c condensate which has maintained my lawn without sprinklers or pest control for over 2 years, The stormwater drains are a mess as they are clogged with dirt and leaves and runoff from contant leafblowers, not to mention roots of the GRAND Oaks that are so revered that they are breaking up the sidewalks, roads, and one imagines, the drains-sanitary and storm,
01/28/2011 9:04 AM
I think Bamboo and Reeds grow in Bar ditches the dead trees could be replaced
with wastewater hardy foliage.Cypress,Palmetta grow in swamps.You didnt
say what variety of trees died.ds
dsuzmay@gmail.com
artsmith (1); Doorman (1); ds (1); Just an Engineer (1); kevinm (1); ozzb (1); RCE (1); RDGRNR (1); terre (1)
