Test & Measurement Blog
Test & Measurement
The Test & Measurement Blog is the place for conversation and discussion about materials and product testing, bench testing, inspection, and test equipment & strategies. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: How Do You Innovate?   Next in Blog: How Can We Lure Engineers Back to Engineering?
2 comments
How Carefully Do You Analyze Product Test Failures?
Posted July 26, 2011 11:59 AM
Knowing that a product has failed a critical test provides some useful information. But if you don't know why it failed, you don't know whether to repair the product or scrap it, and you have no way to prevent similar failures in the future. What information do you get when a product fails? How do you use it to reduce costs and increase quality? Do you also perform a comprehensive analysis of the failure on the production line? Off-line? What do you learn from the extra step, and how do you use that knowledge? What additional information would help you?
The preceding article is a "sneak peek" from Test & Measurement, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Test & Measurement today.
Good Answers: 27
Re: How Carefully Do You Analyze Product Test Failures?
07/26/2011 11:22 PM
Finding or identifying which component(s) failed is only an initial step. Knowing what the role of that failed component in the ckt., device type and specifications, knowing how the device was used in filling-in that role, and coupling all gathered information with any other noted environmental conditions that may have helped triggered the failure. These are factors that should always be considered before putting the system back in service. Identifying, addressing or correcting all these faulty conditions, incorporating them in the failure analysis, will ensure a cost effective approach in mitigating the problem. At the end of this exercise and regardless of what problem was found, economics of things will prevail which will serve as the main determinant whether to scrap or repair?
vsar
08/05/2011 12:01 PM
I teach courses on testing, and I always hit failure analysis hard. I tell my students that if they don't do a thorough failure analysis that they have just wasted time and money doing the test; that a cursory analysis without verifying the actual problem can be worse than none at all. I also highlight that there are times when they may not have the staff to do it but may need to go to an outside expert. In one of my courses I actually had an outside expert, and he admitted in front of the class that even someone trained in analysis cannot always tell the exact stress that caused a failure - for instance, stress from differing thermal coefficients can mimic vibration failures. That helped the rest of the class to understand the reason for doing single environment tests first as a baseline in order to help them with their failure analysis later.
