E&E Exchange Blog
E&E Exchange
Previous in Blog: A Realistic Look at Energy Challenges   Next in Blog: Coal: A Problem or a Solution?
2 comments
Pumped Storage - The Renewable Stabilizer
Posted August 10, 2011 4:31 PM by cheme_wordsmithy
The renewable energy technology field has seen significant growth in the advancement of solar cells and wind turbines. Yet these sources of power are inconsistent, leading to overages or shortfalls depending on day-to-day and seasonal weather conditions.
For a renewable source of consistent power, pumped storage is the answer. Hydro-power is the most widely-used renewable power generation technology today. It currently provides a much larger base of generation compared to other renewable technologies, with OECD North America producing 702,753 GWh from hydro as compared to 59,784 GWh from wind and 2,492 GWh from solar sources.
The International Energy Agency published a report to address the active management of power systems to maintain a steady supply-and-demand balance. The report, titled Harnessing Variable Renewables: A Guide to the Balancing Challenge, says that "Some renewable energy technologies (for example biomass, geothermal and reservoir hydropower) present no greater challenge than conventional power technologies in integration terms." This is because pumped storage technology has the ability to utilize supply-and-demand strategies for "storage" purposes.
Pump storage systems use two reservoirs: a higher reservoir for generating energy during peak usage and a lower reservoir for storing water to be pumped to the higher one during low demand. Like all energy story mediums however, the reality is that these systems are net consumers of electricity.
Because of the push for renewable sources of power, pumped storage facilities should continue to receive attention and development. They provide a renewable means to energy storage and stabilization for variable sources that are beginning to make a bigger impact in the global energy market.
Source: Renewable Energy World
Canada - Member - New Member
Re: Pumped Storage - The Renewable Stabilizer
08/10/2011 11:43 PM
Pumped hydro is the system I usually promote, to the point of recommending that some windmills should just pump water directly, accepting the inefficiency of one extra conversion step for the overall system simplicity and low hardware cost. Pumps even have the advantage of only loosing efficiency if driven by an extra strong wind, rather than burning out. The addition of reservoirs to the landscape can also provide a buffer for agriculture dealing with climate change.
However, where geography favours a cave full of compressed air, and low-grade heat can be useful, we can realize some of the economies of the heat pump. As the air is compressed, we can draw off the heat of compression, and then, between expansion stages, we can re-warm it by ambient heat, for an overall gain in energy. There are situations where the cooling step can also be useful directly for refrigeration or air conditioning.
Good Answers: 179
08/11/2011 11:06 AM
We actually have one such facility a hours drive from here that is owned and operated by the New York Power Authority....it's called the Blenheim-Gilboa Pumped Storage Project that was built in the late 60's and early 70's. It is located about 40 miles southwest of Albany along the infamous Schoharie Creek in the northern Catskill Mountains. The upper storage reservoir is located atop Brown Mtn.. The lower reservoir also provides flood control for the Schoharie Creek watershed. It's a beautiful facility. I've gone through the guided tour inside it twice and still cannot get enough of the place.....you need to make reservations quite a bit in advance in order to take the tour that's directed by one of the NYPA engineers.
Back in the early 70's the NYPA had proposed to construct a second such facility nearby Blenheim-Gilboa (not far from the Village of Prattsville, NY), but it was shelved mainly for environmental reasons....and some very loud political shouting. Too bad, we could use that facility here instead of relying on the aging nuke plant at Buchanan (north of NYC on th Hudson River) that Gov. Cuomo wants the feds to close.
http://www.nypa.gov/vc/blengil.htm
Long live Hydro power!
