E&E Exchange Blog
E&E Exchange
Previous in Blog: Fluorine Face-Off In Electronics Market   Next in Blog: Solar Power: The Best of Times and Worst of Times
2 comments
The Answer Is (Not) Blowing In The Wind
Posted December 15, 2011 9:00 AM by cheme_wordsmithy
Scientists with dreams to harness energy from the upper atmosphere may have their head in the clouds…
High speed winds in the upper atmosphere, also known as jet streams, have in recent years gained considerable attention as a potential source of energy. It seemed like the only hurdle (granted a big hurdle) to overcome in this area was creating effective wind turbine technology at these altitudes. If it could be developed feasibly and cost effectively to reach those heights, it was thought that the energy potential would be sufficient for most if not all of the world's energy needs.
An artificial image depicting what jet stream turbines might look like. Image Credit: Max-Planck-Institut
The Science Behind Jet Streams
The enormous potential of high-altitude wind energy is from jet streams, which are regions of continuous wind speeds in excess of 25 m/s (55.9 mph) which occur at altitudes of 7-16 km. Like any other weather or wind system, jet streams ultimately exist because the sun heats certain regions more strongly than others (regions around the equator are heated much more than the poles). The resulting temperature and air pressure differential drives movement in the atmosphere, also known as wind. The upper limit on the amount of wind generated is set by this differential heating.
Visible jet stream. Image Credit: Shuttershock
The fact that jet streams in the upper atmosphere move much faster than winds near ground level is due to the near absence of friction. Due to low air density and the lack of contact with the surface, jet streams encounter little flow resistance. With help from Coriolis forces (due to the Earth's rotation), these winds require little energy to sustain themselves.
What This Means
Because it takes little power to generate and sustain jet streams, the amount of energy that can be captured is also small. "It is this low energy generation rate that ultimately limits the potential use of jet streams as a renewable energy source", says Dr. Axel Kleidon, head of the independent Max Planck Research Group 'Biospheric Theory and Modelling'. In other words, high velocity winds do not necessarily equal strong and powerful winds. Through climate models based on atmospheric energetics, Kleidon's group estimated the total amount of energy which can be extracted from the atmosphere. The maximum of 7.5 TW (1 TW = 1012 W) is 200-times less than previously reported, accounting for about half the 2010 global energy demand of 17 TW.
Graphics depicting the map of energy transport (top) and extraction rates (bottom). Image Credit: Max-Planck-Institut
In addition, if a large portion of this energy was extracted from the jet streams, their natural flow and shape would be altered, depleting the atmospheric pressure gradient between the equator and the poles. "Such a disruption of jet stream flow would slow down the entire climate system. The atmosphere would generate 40 times less wind energy than what we would gain from the wind turbines", explains Lee Miller, first author of the study. "This results in drastic changes in temperature and weather".
What this means is that jet stream wind power may not be the promising energy solution of the future it was expected to be. Its potential to be harvested economically as a supplement to other energy sources is now, more than ever, very much up in the air.
Sources:
Max-Planck-Institut
ScienceDaily
Re: The Answer Is (Not) Blowing In The Wind
12/16/2011 3:56 PM
Another Green technology bites the dust. After further research, we find a great idea may not be so great, either because of little return for effort or other unintended consequences. We do need to explore all available ideas, but we also need to cut our losses when somethings after much researching does not work.
12/17/2011 2:31 PM
I consider this to be just one more example of not everything works well everywhere.
Wind power works great in places that have high enough average winds just the same as hydro electric only works best where there is an abundant and continual source of running water. Wind power does not work well where there is little wind just the same as hydro electric does not work well in the middle of a dry dessert.
All forms of energy, AE or otherwise, fall into the same line of issues. What works well where the condtions are good does not mean it will work well somplace else that does not have those similarily favorable condtions.
These should not be difficult engineering concepts and principals to understand and work with but for some reason they clearly apear to be.
