Notes & Lines Blog
Notes & Lines
Previous in Blog: Impossible Objects: Messing With Your Brain Since 1934   Next in Blog: H2Organology: Hydraulic Instruments
9 comments
The "Sonic Barber Pole"
Posted December 14, 2012 11:06 AM by Hannes
Have you been known to say "I thought I heard…"? Or have been certain you heard something correctly only to realize your perception was completely incorrect? For those who are getting older or have been with a partner or spouse long enough, both of these are increasingly common occurrences. But rest easy, friends: the seemingly infinite Shepard scale illusion laid out in this post will be misheard by all.
The Shepard scale was developed by cognitive scientist Roger Shepard, and relies on a combination of pitch and volume to achieve its never-ending effect. Shepard's effect is quite simple and begins with two identical pitches an octave apart. While the tones ascend through the scale, the higher tone gradually diminishes in volume, while a third tone below the original lower tone begins to sound almost inaudibly and increases in volume as it ascends. Eventually the original high tone becomes inaudible and the scale returns to its original position, only to continue ascending. A crude realization sounds a little like this (complete with helpful spectrogram).
The image below is a little confusing, but nicely illustrates the Shepard principle. The graphic representations of pitch below are color coded by volume, with purple indicating the lowest amplitude and teal / yellow indicated the highest. We can see that, just as the higher tones fade, a new set below becomes increasingly strong and takes their place.
...Via Wikipedia
Jean-Claude Risset, a French electronic composer, subsequently altered the scale to blur the tones together, which in my opinion creates an infinitely neater effect. Here's a looped audio example of the Shepard-Risset glissando, in which a complete cycle occurs every 30 seconds or so.
The Shepard scale is sometimes referred to as a "sonic barber's pole" and shares many characteristics with this classic optical illusion. Both contain seemingly endless information loops, and both mask information that assists in fooling our actual perception. Both also share one trait of all sensory illusions: playing on our brains' ability to assimilate limited amounts of information. When we listen to a Shepard scale, we are able to compare the current tone with the previous tone that we've heard, but not all the previous tones in the scale. This sort of auditory "aperture" is identical to the visual aperture that makes the barber pole illusion possible: by limiting the candy stripes to a narrow vertical cylinder, it gives the illusion that they are endlessly swirling down. If the same visual material was presented in a horizontal aperture, we would be fooled into thinking it was endlessly swirling sideways.
So, the next time you botch an important project detail or forget an item on your honey-do list, try blaming the pitch and amplitude of the instructions - it just may get you off the hook.
(...Ear trumpet image via Leeds Museum | Barber pole via Vimeo)
Re: The "Sonic Barber Pole"
12/14/2012 11:25 AM
"So, the next time you botch an important project detail or forget an item on your honey-do list, try blaming the pitch and amplitude of the instructions - it just may get you off the hook."
Yeah... be sure to let us know how that works out for you.
Good Answers: 69
12/14/2012 11:42 AM
I already constructed the scene in my mind and I don't think it would work for anybody.
12/14/2012 11:48 AM
I'm with you. The people for whom I work and the person who gives me a honey-do list will never buy into that!
Good Answers: 145
12/15/2012 7:15 PM
The biggest problem with SWMBO's and Mere blokes is the communication protocols are wrong nevermind the baud rate.. SWMBO's are Asynchronos communicators, Mere Blokes (like me) are Synchronos.
Needless to say I only ever manage to decipher half of what she tells me...
* SWMBO= She Who Must Be Obeyed
There are two reasons for a man to do a thing, One that sounds good, and the real one...
12/15/2012 3:27 PM
barber poles don't seem to rotate fst enough to cause this effect i think they are meant the replace a simple sign. a barber pole is more noticable at a longer distance. it would me interesting to know how long they been used as a standard symbol for a haircut, shave, or surgery.
Good Answers: 101
12/17/2012 7:41 PM
My wife informed me that it symbolized (or advertised) bloodletting.
She is a trained and licensed cosmetologist/esthetician and should not be questioned on any facts or myths regardless of origin or discipline.
It's also very helpful to simply nod, smile, and say "OK honey".
She would enjoy my feeble attempt at getting out of work with that excuse, and make sure I knew it simply made my list grow to include a foot rub or similar.
See more on the pole here: http://en.wikipedia.org/wiki/Barber's_pole
12/14/2012 10:35 PM
About a year ago I suggested to the wife that she raise the pitch a bit and speak more crisply. After a few times of her being reminded of this, during the honey-do list, she went about the list herself and speaks only when she needs direction. Life is good.
12/15/2012 1:49 AM
In my case it is a 'Don't do' list. The appellation is not 'Honey' either. Lot more acidic.
bioramani
12/15/2012 9:29 AM
My honey do list is constantly being revised and constantly being spoken when SHE is awake....I'm now deaf to anything she says that starts.."When are you..."
bioramani (1); Doorman (2); durtieduck (1); mog (1); RVZ717 (1); Tobugrynbak (1); Tom_Consulting (1); Yahlasit (1)
