  • Core HVAC Technologies
  • Manufacturing Technologies
  • Product Quality Improvement
Previous in Blog: Helping Small Companies in Emerging Markets Strengthens the Global Economy   Next in Blog: Are You Ready for 3-D Printing?
4 comments
Cleanliness Considerations for Systems using Hydrofluorocarbon (HFC) Refrigerants
Posted November 13, 2013 8:00 AM by larhere
By now, CFCs such as R12, R502, and R11 and the main HCFC, R22, have been banned from new unitary and commercial HVAC&R equipment due to ozone depletion concerns. These refrigerants have been replaced - for the time being at least - by HFCs such as R410A, R134a, and R407C. In making this transition, the industry has had to address many issues with HFCs concerning reliability, safety, and performance. This article deals with major cleanliness issues when manufacturing equipment using HFCs.
Process Fluids
Using any HFC refrigerant such as R134a, R407C, or R410A means it is necessary, due to solubility concerns, to use polyester (POE) lubricants in the compressor instead of the mineral oils used for decades with HCFCs and CFCs. It is important to note that many process fluids used in the manufacture of compressor components, coils, tubing, and other parts, which were not incompatible with mineral oils can be damaging to a system using POEs. Refrigerant/lubricant Solubility characteristics can be altered. More importantly, carbonaceous
matter can precipitate within the lubricant and, as it circulates through the system, it will deposit within the expansion device. When the expansion device becomes restricted during field operation, it becomes necessary to make costly service repairs. It is imperative that (1) all vendors supply refrigeration components completely clean and free of process fluids and (2) that process fluids used in the assembly of components be removed before the system is evacuated and charged.
Moisture
Water can be more damaging to an HFC/POE system than the usual HCFC/mineral oil system, although it is undesirable in all systems. The fact that synthetic POE is manufactured with complex acids and water means water can tend to reverse the process, leading to chemical breakdown of the system. It is therefore highly recommended that all HFC systems contain a drier from a reputable supplier.
Minimum water removal capacity for a system drier should be 1.2 drops per lb. refrigerant in the system. A system with 10 pounds of refrigerant should have a minimum water removal capacity of 12 drops. Note: Drier manufacturers rate their products in drops at 60 ppm end point dryness. There are 20 drops per gram of water.
Editor's Note: CR4 would like to thank Dick Cawley of GEA Consulting for contributing this blog entry.
Good Answers: 102
Re: Cleanliness Considerations for Systems using Hydrofluorocarbon (HFC) Refrigerants
11/14/2013 1:59 AM
Wouldn't the conventional practice where vacuum pumping, and holding the vacuum to boil off any water , of refrigeration systems prior to charging with refrigerant remove the water?
11/16/2013 10:04 AM
Certainly one should always evacuate any system to remove water vapor and hold the vacuum to help check for leaks. However, tests have shown that all standing liquid water will not be removed under vacuum for many hours of pump application. The asistance of a drier is very important.
United States - Member - Old Member
11/14/2013 5:04 PM
All is true in this Blog Entry. But, don't we always install or replace driers when opening a system?
11/16/2013 10:14 AM
Certainly we should always replace the drier when opening a system in the field, but in the past not all technicians did so. Also, manufacturers often did not apply driers in original equipment. This was with R22 and R12 systems. This message is intended to stress that we cannot get by with such practices with HFC/POE systems.
hvacpe (2); Sasnak (1); Wal (1)
