E&E Exchange Blog
E&E Exchange
Previous in Blog: The Power of the Sun...   Next in Blog: The WV Spill and Its Effect On Clean Coal
10 comments
Wireless EV Charging
Posted November 29, 2013 8:00 AM by cheme_wordsmithy
One of the biggest problems plaguing electric vehicles (EVs) on the market today is their limited range between charges - typically only 50 to 150 miles. Add to that the inconvenience of long charge times and limited availability of charging stations, and we can understand why these vehicles are not yet a truly hot commodity. Researchers at North Carolina State University (NCSU) have been developing technology which could one day provide a solution to the range problem - wireless charging via transmitters under the road.
Wireless charging sounds like something from a science fiction movie: cars getting power from the road like an electric train, but with freedom of movement and no track or visible power transfer. In reality, wireless charging is as real as your electric toothbrush charger, and is in development on a larger scale for consumer electronics and electric cars alike.
The mechanism for wireless charging is magnetic induction, where a coil through induction creates an electromagnetic field which can be picked up by a receiving electrical device to draw power and charge a battery. In consumer electronics applications (e.g. cell phone charging), the field is generated via a charging station. In EV charging, it is from a transmitter positioned under the surface of the car.
Stationary wireless EV charger - via gizmag.com
NCSU researchers have developed a system that uses a specialized receiver to induce bursts of power when a vehicle passes over a wireless transmitter. Compared to typical stationary inductive chargers for EVs (see image above), this technology is more energy efficient, eliminating the need for complex sensors or power electronics. Instead of using sensors, NCSU's charger emits a weak magnetic field which becomes strong when a car passes over due to electronics in the receiver. The system also incorporates inductors and capacitors to assist power transfer between the transmitter and receiver, in the place of more energy sapping power electronics. These cost and efficiency benefits are important when considering the application: hundreds to thousands of these placed underneath roadways.
The researchers at NCSU have produced a low-power proof-of-concept of their charger (seen right), and the intent is to scale up to a rate of 50 kilowatts, which is equivalent to direct-current (DC) fast charging stations. How this research develops remains to be seen, since scale is a big factor when it comes to this technology.
NCSU's prototype - via technologyreview.com -->
How much of an affect could these chargers have? According to an assistant professor at NCSU, adding these chargers to 10% of a roadway would extend the range of an EV from 60 to 300 miles, closing in on the range of standard gasoline-fueled cars.
Like many possible technologies for the future, the biggest hurdles to wireless EV chargers are the infrastructure and maintenance costs. Implanting coil systems into even 10% of the U.S.'s major roadways seems a like daunting and unrealistically expensive task.
A more feasible use of this technology might be to place charging technology in strategic locations, such as bus stops or at traffic lights. The University of Utah has tested a wireless charging infrastructure for city buses, and has created a company called Wireless Advanced Vehicle Electrification to build commercial products. It will be interesting to see how this technology advances; its fate may be closely tied to the success and evolution of the EV market.
Source Article: Technology Review
Re: Wireless EV Charging
11/29/2013 2:13 PM
Their range problem is not a charging issue. Its a pinhead engineering issue. 40 years ago the first public EV's had ranges of 30 - 70 miles running on nothing more than heavy inefficient lead acid golf cart batteries.
Now jump up 30 years to the Lithium based battery tech we have now that packs over 10x the usable energy in the same space while weighing nearly half as much which by the number should mean that a modern EV should be getting 300 - 700 miles on a charge.
The range problem is that the idiots making the new EV's pack so much useless unneeded high power drain crap onto the new EV's that they are starting out from day one half crippled from it. Then on top of that to save money they cut the battery systems down to way smaller physical sizes and weights than the old LA based systems used.
The next big problem is the drive system tech is way way over engineered and priced to do what should be a simple thing. The industrial and mining industry pioneered electric drive trains half a century or more ago. They figured out how to make them simple rugged robust and highly reliable. What we have now in EV drive systems is complex fussy and not nearly as reliable as we are lead to believe. Especially when compared to industrial EV drive systems.
Personally if having a Cummins in your pickup is some sort of representation of industrial design showing up on everyday private vehicle applications I want to see something like, "drivetrain by GE or Siemens or Pierce or WEG or some major electric drives manufacturing company that deals with industrial power drives and control systems!" on a little tag on the side of an EV!
11/30/2013 10:39 AM
In 1979, I was a co-founder of an electric car company, Electromotion, Bedford, MA and we introduced an electric car that was designed from the ground up to be an electric. We used "golf cart" batteries and the 2,500 lb car had an effective range of 40 miles but in two minutes the battery pack slid out of the car on internal rollers and was replaced with a charged pack. We were driving the vehicle a total of 400 miles a day in the Boston area. When I designed the vehicle I spent time with the utility companies who were trying to find ways to decrease energy consumption during "peak demand" periods and the obvious solution was to charge at night. Also fast charging produced major "connection" problems. Our goal was to encourage the leasing of batteries and for battery manufacturers to operate "exchange" stations.
11/30/2013 10:53 AM
Hey TCM, the reason you won't see those badges is the same reason you won't see the necessary nuclear plants going up. We are totally in big oils pocket.
How else can you explain the fact that we have the engineers , the technology, the infrastructure and the money to go electric and yet we are still burning COAL? and our cars still run on gas not diesel and they don't even get as good mileage as the a 1979 Honda civic or a 1980 VW diesel rabbit? There is something fundementally wrong with 40 years of innovation that results in poorer performance and fuel economy don't you think?
Kinda counter intuitive.
11/30/2013 2:50 PM
Believe me I already know why.
I am over in Antalya Turkey for the month visiting my wifes family.
We just rented a 2013 Chevy Aveo four door diesel. Today we took everyone, five adults and one kid, for a ride up into the Turkish mountains.
Overloaded, steep roads and driven like a rental car and I still couldn't get the MPG readout to stay under 42 MPG!(5.6 l per 100 km)
From what I can find online this model with the diesel is not available in the US.
(I wonder if it has anything to do with it having a mid 50's MPG in town driving rating and a mid 60's MPG highway rating?)
11/30/2013 3:04 PM
You can count on that my friend.
High mileage diesel engine powered cars are all over the world except here.
11/30/2013 11:45 PM
I'm seeing a lot of models of vehicles over here that are not allowed in the US (for emissions reasons of course) and so far every one I have been able to find info on has base MPG numbers substantially above their US versions.
A lot of the taxis here are running on LPG and if my wifes number translations are right even they are pushing upper 20's to mid 30's MPG numbers doing nothing but stop and go in city driving.
The thing that annoys me the most is almost all of the vehicles here are major name brands found in the US. Ford, Chevy, Toyota, Nissan, Mazda, Honda, Kia, Subaru, BMW, Mercedes, Volkswagen and so on which to me clearly shows these vehicle manufacturers know how to make their stuff get way better fuel mileage than they do in the US.
Good Answers: 140
11/29/2013 3:09 PM
At a recent Canadian Electrical Code committee meeting these wireless charging systems came up.
Apparently there are all sorts of health issues that go along with these devices. The bottom line... human beings do not like being in the presence of large magnetic fields for very long. The fields appear to be blamed for all sorts of issues and can cause all sorts of issues for the various man made components many of us have inside us.
Stay tuned... Oh... and stay away from that 50 kW "air gap" transformer.
11/29/2013 4:43 PM
Check the range on a Tesla.
If it were not for big oils strangle hold on the US government we would be the world leaders in this technology.
BTW, S. Korea opened the worlds first electrified roadway this year.
Good Answers: 151
11/29/2013 5:25 PM
In all these discussions and speculations about the development of EV's no one seems to address the question of where the electrical energy required to power them is going to come from. Wireless charging from embedded roadway grids? Great! But where is this power going to come from, coal fired power plants, nuclear power plants, wind or solar power (but not in my back yard). How will it be metered, and taxed. Yes, someone has to pay for these roadways when we can't even pay to maintain our current roadways.
Reply Good Answer (Score 4)
11/30/2013 8:43 AM
And we need to make detour signs for people with pacemakers!
gringogreg (1); North of 60 (1); rashavarek (3); Rixter (1); tcmtech (3); Wayne Goldman (1)
