Roger's Equations Blog
Roger's Equations
Previous in Blog: Feats of Engineering! by Roger Pink   Next in Blog: You Are Here (And Other Random Thoughts) by Roger Pink
2 comments
It's a Coin Flip by Roger Pink
Posted February 27, 2014 6:16 PM by Bayes
Binomial Distributions
A binomial distribution has the form;
with a mean of
variance of
and standard deviation of
The binomial distribution is the discrete probability distribution of the number of "successes" (positive results) in a sequence of n independent yes/no experiments, each of which yields a "success" with a probability of p. Let's see an example.
An Example
Imagine you flip a coin 4 times in a row. Here are the possible outcomes:
TTTT = 0 heads
HTTT = 1 Heads
THTT = 1 Heads
TTHT = 1 Heads
TTTH = 1 Heads
TTHH = 2 Heads
HHTT = 2 Heads
THHT = 2 Heads
HTTH = 2 Heads
THTH = 2 Heads
HTHT = 2 Heads
THHH = 3 heads
HTHH = 3 heads
HHTH = 3 heads
HHHT = 3 heads
HHHH = 4 heads
The above shows that if you flip a coin 4 times in a row, you can get anything from zero heads all the way up to 4 heads. The probability of getting heads zero, once, twice, three, or four times for an unbiased coin are respectively 1/16, 4/16, 6/16, 4/16, 1/16. When we plot this as a histogram, we are plotting the distribution.
Use The Formula, It's Quicker
Rather than writing out every possible iteration and counting up results as we did above, let's use the formula at the top instead.
For example, let's calculate the probability of 2 heads coming up in 4 throws. That means that k=2, n=4, and since we are using an unbiased coin, p=1/2. Subbing the values into the equation from the top we get;
Let's see how it works for heads coming up zero times in 4 throws (k=0, n=4, p=1/2)
keeping in mind that
thus
Success! I'll leave it to you to try the other two scenarios (k=1 and k=4).
The Mean, Variance, and Standard Deviation
The mean of the distribution that forms from 4 flips of an unbiased coin is:
Which seems correct when we look at the distributions.
The variance is
Finally the standard deviation is
Let's Supersize our Coin Flips
So now that you know how to do the calculations, let's look at some other results.
Flipping a coin 10 times (n=10 p=1/2), for k's 0-10 we get the following probabilities:
1/1024
10/1024
45/1024
120/1024
210/1024
252/1024
210/1024
120/1024
45/1024
1/1024
mean=5
variance=2.5
standard deviation=1.58
20 Flips
Flipping a coin 20 times (n=20 p=1/2), for k's 0-20 we get the following probabilities:
1/1,048,576
20/1,048,576
190/1,048,576
1140/1,048,576
4845/1,048,576
15504/1,048,576
38760/1,048,576
77520/1,048,576
125970/1,048,576
167960/1,048,576
184756/1,048,576
167960/1,048,576
125970/1,048,576
77520/1,048,576
38760/1,048,576
15504/1,048,576
4845/1,048,576
1140/1,048,576
190/1,048,576
20/1,048,576
1/1,048,576
mean=10
variance=5
standard deviation=2.24
100 Flips
Flipping a coin 100 times (n=100 p=1/2), for k's 0-100 we get the following probabilities:
mean=50
variance=25
standard deviation=5
Poisson Distribution
The Poisson distribution can be derived from the binomial distribution by making a few assumptions. I recently did this derivation in my other blog on CR4. Please check it out if you're interested.
Re: It's a Coin Flip by Roger Pink
02/28/2014 3:30 AM
Just to rework an oldie;
I invite you to meet for lunch every day for the next year. Being a sporting chap I suggest we take turns flipping a coin to see who pays - first person to flip 'heads' pays. I'm so generous that I let you flip the coin first on each occassion. Do we have a date(s) ?
Good Answers: 151
03/01/2014 11:01 AM
On a similar note, the probability of tossing n consecutive heads (or tails) in a row is 1/2^n for example the probability of tossing 10 heads in a row is 1/2^10 = 1/1024.
Now suppose I have just tossed 9 heads in a row. What is the probability that my next toss will also be a head?
You would be surprised how many people get this wrong. Las Vagas casinos are filled with them.
