Roger's Equations Blog
Roger's Equations
Previous in Blog: The Internet of Things   Next in Blog: Vernal Equinox (Spring Is Here!)
8 comments
Take It To The Limit by Roger Pink
Posted March 13, 2014 3:43 PM by Bayes
Limits!
A limit is the value that a function f(x) approaches as the input (x) of that function approaches a value. Sometimes it is useful to take the "limit at infinity". This is basically saying, as x gets larger and larger, does the function converge upon a certain value (0, 15, 972, 1/3, 2.71828..., etc.) or does the function diverge (∞,-∞, etc.)?
Let's look at an example to see how this works:
So the above says "as x gets larger and larger and larger, the function 1/x approaches 0". Does that make sense?
1/10, 1/100, 1/1000, 1/10000,.... Yup, seems to be heading towards zero. Let's look at another example.
Ok, sure. We care about where it's going, not how fast it's getting there. This function is definitely approaching zero as x gets larger. Getting there faster than the last function (1/x) too.
Ok, so this is less clear. Certainly written this way the answer isn't obvious. Best to rewrite it using some algebra.
And that is how it's done. Use some algebra to reduce it to a form that is clear to solve. Here are some examples:
Sometimes the limit doesn't converge. Here's an example:
Makes sense. Certainly as x gets larger and larger, x gets larger and larger. Please remember that infinity is not a number, but an idea. It basically means "continues on". So the limit of a function that equals infinity is not converging at a number but diverging (continuing on). Here's some more examples:
Here's a few more examples of limits of functions that converge. Again, these need to be modified algebraically in order to clearly see the limits they converge to.
If you are confused as to how any of the above were solved, please check out this great link that will explain in detail the algebraic steps taken to find the limit.
U C Davis Math ~ Limits
Astronomy Fans!
Some cool news regarding our local Galactic Neighborhood. Find the article here.
It reads:
We live in a galaxy known as the Milky Way -- a vast conglomeration of 300 billion stars, planets whizzing around them, and clouds of gas and dust floating in between. Though it has long been known that the Milky Way and its orbiting companion Andromeda are the dominant members of a small group of galaxies, the Local Group, which is about 3 million light years across, much less was known about our immediate neighborhood in the universe. Now, a new article maps out bright galaxies within 35-million light years of the Earth, offering up an expanded picture of what lies beyond our doorstep. Cont. Here
If you haven't had a chance, check out "You Are Here" found on my website (Roger H Pink) which explains where we are in the universe at various scales.
As always, thanks for stopping by and reading my blog. - Roger
Re: Take It To The Limit by Roger Pink
03/14/2014 7:15 AM
Aw that's a cheesy title even by my standards !
I'm awaiting comparartive solutions for cubic equations. I've got a really cool one that I learned years ago. Stays in my mind because it's relatively easy to understand how it's derived. That said I'll be well shame-faced at the time it takes me to recall it.
Good to have you back but please slow down. You deserve a coffee break !
The Engineer
Good Answers: 129
03/14/2014 9:20 AM
Naming these blogs is half the fun! (Great Videos!)
03/14/2014 5:37 PM
Totally agree, it's fun and it helps to draw people in. Am awaiting the blog that starts 'I have a cartesian math prob' (Del put me up to that ).
Here's silly; I forget to put the plug in, and run a bath. Taps spout x litres per minute. The drainage rate is less, and is going to depend upon the head of water (ie how full the tub is). I suspect the formula may not be as easy as first thought indicates). The more the tub fills, the faster it drains. I'm thinking that with a big enough tub equilibrium can be reached, but it's late at night and I'm not sure...........
03/14/2014 8:28 AM
How about lim ((x)(x+1)/2) as x->∞?
03/14/2014 9:33 AM
lim ((x)(x+1)/2) as x -> Infinity?
The way you've written it seems pretty straightforward, unless you missed a parentheses:
(x)*(x+1)*(1/2)
Remember, order of operations and priority in algebra, 1) parentheses, 2) Multiplication and division, 3) addition and subtraction.
So we have X increasing and a constant stating constant, so the limit approaches infinity.
03/14/2014 10:16 AM
Sum of x=1,2,3,... = (1/2)(x)(x+1)
http://cr4.globalspec.com/blogentry/24184/1-2-3-4-1-12-Seriously-by-Roger-Pink
03/14/2014 10:36 AM
Ah, I see the formula you're going for there:
Sum of 1+2+3+...+n
X= (n(n+1))/2
But when looking at it for limits, it's a simple first-order equation of y=x*C, as x increases, y increases.
03/14/2014 6:49 PM
It may look simple, but Rixter does have a point.
x
Σ n = (x2+x)/2
n=1
so...
Σ n = (∞2+∞)/2 which we have been told is equal to -1/12
n=1
What keeps us from just finishing this up and reaching a convenient value for that lemniscate?
What keep the proceeding from allowing us to conveniently input '-0.5 ± 0.3' for every '∞' we come across?
adreasler (2); Bayes (1); Kris (2); Rixter (2); truth is not a compromise (1)
