Roger's Equations Blog
Roger's Equations
Previous in Blog: 3D Printing: Fad or the Future?   Next in Blog: Top 5 Favorite Blogs/Articles from 2014
2 comments
What Do Turkey Timers and Sprinkler Systems Have in Common?
Posted December 23, 2014 3:52 PM by Bayes
Fusible Alloys
Fusible alloys or low-melting alloys have some interesting properties, but often are overlooked. Their solidification characteristics make them useful for tooling applications as well as components in product design.
Fusible alloys have low melting points, usually below 300 degrees Fahrenheit or 150 degrees Celsius. Many fusible alloys have eutectic compositions, which provide an alloy with a distinct melting point similar to a pure metal. Non-eutectic fusible alloys would melt over a range of temperature and act slushy between their liquidus and solidus temperatures. Many fusible alloys are based on bismuth alone or bismuth in combination with lead, tin, antimony, gallium, cadmium, zinc and indium. Some fusible alloys are based on gallium or indium.
Bismuth-based fusible alloys are desirable because of the pure bismuth's characteristic of expanding 3.3% upon solidification. The bismuth content in a fusible alloy is adjusted to produce a fusible alloy with desirable shrinkage or expansion characteristics. Bismuth alloys containing more than 55% bismuth expand while those with less than 48% contract during solidification. Alloys with bismuth levels between 48-55% exhibit little change in volume when they solidify.
Article Continues Here...
Re: What do turkey timers and sprinkler systems have in common?
12/23/2014 9:31 PM
Good post Roger.
This touches on something that I've been thinking about lately...what happens when the lights go out?
Both the sun and our earthbound enemies have the potential to shut down everything that involves electricity.
Will engineers be able to fill the void, or will we start from scratch, with these alloys serving as simple switches?
There are a lot of smart people on here, but can they function without the juice?
Good Answers: 94
12/24/2014 7:42 AM
We use indium/bismuth & indium/tin for sealing optics into our vacuum devices, both are eutectic. We can see the eutectic nature when we wet the indium alloy to the nickel steel part that holds it. This takes place in vacuum under a bell jar with heating by induction from outside the jar. You can see the indium go from solid to liquid instantly.
