Animal Science Blog
Animal Science
The Animal Science Blog is the place for conversation and discussion about scientific and technological topics related to pets, livestock, and other animals. See how cutting-edge advances help - or hinder - species around the world.
Previous in Blog: The Science of Your Bird Feeder   Next in Blog: Brontosaurus vs Apatosaurus
9 comments
A Fishy Mystery
Posted March 24, 2015 12:00 AM by Chelsey H
So admittedly I have never thought of this before, but do fish get out of breath?
Fish rely on their gills to remove oxygen from the water. Gills are feathery organs full of vessels. A fish breathes by taking water into its mouth and forcing out through the gill passages. As water passes over the thin walls of the gills dissolved oxygen moves into the blood and travels to the fish's cells.
All of the roughly 30,000 different types of fish need oxygen. However, different types of fish respond to exertion in different ways. For example, salmon must work hard to traverse rapids or waterfalls but they will tire before they run out of oxygen. Part of this is due to the cool water that they live in having more dissolved oxygen.
Tropical fish on the other hand live in warmer water with less oxygen and have made several adaptions to compensate for their environment. The types of fish that are sold for home aquariums will engage in "aquatic surface respiration." They swim upwards towards the top-most layer of water, which has been exposed to the air and therefore contains more oxygen. Fish such as sculpins and gunnels pop out of the water for gulps of air and others such as lung fish use internal organs as makeshift lungs, absorbing oxygen into the blood through the walls of their mouth, swim bladder, or even stomach. Image Credit
Luckily for fish, they will never get so short of breath that they pass out. The fish will rest near the sea floor to save energy or surface in search of oxygen first.
Re: A Fishy Mystery
03/24/2015 9:15 AM
My understanding is that the "urge to breathe" is actually triggered by high levels of carbon dioxide in the blood and not low levels of oxygen. Hyperventilating will flush the carbon dioxide out of the body allowing you to hold your breath longer.
Re: A Fishy Mystery
03/25/2015 1:55 AM
Are you a fish?
How would you know!
Thats a bit fishy, isn't it?
Re: A Fishy Mystery
03/25/2015 7:24 PM
OK, I swallowed that one hook, line, and sinker.
Re: A Fishy Mystery
03/25/2015 9:27 AM
This is true of adult humans, but not true of rabbits, and possibly also of infant humans, in which a lack of oxygen is also a stimulus to breathing more deeply. I suspect that in fish a lack of oxygen is an extremely powerful stimulus to their systems for passing water through the gills.
Re: A Fishy Mystery
03/24/2015 1:31 PM
I would expect that either prey or predator contests are frequently decided by one fish or the other getting out of breath.
Re: A Fishy Mystery
03/24/2015 6:01 PM
I thought high levels of lactic acid brought about by carbohydrate utilization was the measure of exhaustion.....?
Good Answers: 42
Re: A Fishy Mystery
03/24/2015 11:26 PM
I volunteer at a salmon fish hatchery.
My observation is that if the O2 levels in the water drop too low the fish do react. They start by finding faster flowing water, the gill action increases, some will start to gulp air. As the 02 decreases further the fish become lethargic and will appear to be dead and floating in the water. If 02 is restored some will recover, but others will die.
The problem occurs when we have a power or water flow failure. We have 10's of thousands in the tanks. When the O2 is stopped we have about 30 minutes before 50% are dead. after 2 hours we have about a 10% survival.
We use soda water (CO2) to "calm" steelhead salmon when we want to harvest the eggs without sacrificing the fish. They recover quickly when put back into the stream.
Re: A Fishy Mystery
03/26/2015 11:19 AM
"We use soda water (CO2) to "calm" steelhead salmon when we want to harvest the eggs without sacrificing the fish. They recover quickly when put back into the stream."
Why does this remind me of beekeepers 'smoking' a beehive to get at the honey without triggering a swarm attack?
Re: A Fishy Mystery
03/26/2015 3:47 PM
That carbonated water has a calming effect on fish is interesting, and certainly suggests fish respiration is probably controlled differently than our own. High levels of CO2 for humans typically favors the exact opposite of calm.
adreasler (1); GW (1); IdeaSmith (1); phph001 (1); redfred (1); Rixter (2); SolarEagle (1); truth is not a compromise (1)
