Previous in Forum: Calculate the probability   Next in Forum: Integrate 1/x^2+80x+1600
12 comments
calculate the probability
03/21/2015 1:04 PM
The time to complete a construction project is normally distributed with a mean of 80 weeks and a standard deviation 8 weeks.
(i) What is the probability that the project will be completed in 84 weeks or less?
(ii) What is the probability that the project will be completed in 92 weeks or less?
(iii) What is the probability that the project will take longer than 90 weeks?
Time waits for no one.
Pathfinder Tags: mathematic;probability
Re: calculate the probability
03/21/2015 1:08 PM
Do your own homework.
Rule:
Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
03/21/2015 1:36 PM
  • What is the probability distribution?
  • Will this be continuous time or discrete time distribution?
  • Will you be able to defend your answer when the project gets completed at a different time than you predicted?
Do your own homework or at the very least show us some initiative that you understand some of your homework.
03/21/2015 2:42 PM
In my opinion, if we did not replace after each draw, for example, the answer of ii should be:
P (B) = 4/20=0.25
P(BR)= P(B)x P(R)=(4/20)X(6/20)=0.06
P=P(R|B)= P(RB)/P(B)=0.24
but when considering replacement, it should be:
P=P(BR)= P(B)x P(R)=(4/20)X(6/20)=0.06
03/21/2015 10:55 PM
You're mixing up your threads here. However, this is a good place to insert some pertinent information.
To calculate the probability that a project task will be accomplished can be reasonably approached using a Weibull distribution. Seeing your other thread on probability, this problem of predicting when a project will be completed and the mathematics of a Weibull distribution is beyond you.
I'm not sure if you are behind in your schooling or reaching farther than you should.
03/21/2015 11:19 PM
I have realized that whether I do well in exam or not, something certain is that I have gone wrong because I used to study just for study itself, exam and I don't care about whether I can remember it or not at next term. But this is a terrible habit which I have to change now. It's you who make me realize my own problem and remind me of self-examination. Thanks a lot.
03/21/2015 2:50 PM
This is my thought.
03/21/2015 10:36 PM
Yeah, I agree with you. I should exchange thoughts instead of using someone else's answer. I will do it time. Thank you for reminding me.
03/21/2015 2:22 PM
(i) 0
(ii) 0
(iii) 0
Experience has shown that all projects have at least a 20% overrun.
03/21/2015 3:34 PM
50-50
03/21/2015 7:02 PM
Depends on whether the environmental impact statements have been approved by the local authorities and the EPA yet. If they are not yet approved, the project probably won't be completed for at least 280 weeks.
03/21/2015 10:23 PM
Haha, you're quite humorous.
03/23/2015 1:59 PM
Since your data are normally distributed, convert each number of weeks to a z score and consult your table.
i) P(x≤84): z=(84-80)/8=0.5, Answer = 69.15%
ii) P(x≤92): z=(92-80)/8=1.5, Answer = 93.32%
iii) P(x>90)=P(x≤90): z=(90-80)/8=1.25, Answer = 10.56%
Register to Reply 12 comments
Brave Sir Robin (1); Fredski (1); Jupiter (5); lyn (1); redfred (2); reward54 (1); Rixter (1)
