Previous in Forum: Cherry Picker Arthritis   Next in Forum: Comparing Work Required At Compressing Gas & Pumping Liquid
Effect at Mechanical Properties Due to Excessive of Time
03/25/2015 4:22 AM
in carbon steel what is effect in mechanical properties due to excessive soaking time.
Re: Effect at Mechanical properties due to Excessive of Time
03/25/2015 4:27 AM
More info please!!
Soaking in water? Acid? Oven at 400 Deg C?
How excessive?
5 mins? 5 hours? 5 days? 5 years?
What size piece? I suspect that smaller pieces would be more affected if the atmosphere included other impurities.
I'm asking this as an EE knowing that the metallurgists and other specialists will need detailed specifics before they could even begin to respond in a meaningful manner.
03/25/2015 6:22 AM
1)Material
SA-516-70
2)Thickness
25MM
3)Holding Time
2 Hours 15 Minutes
4)Holding temperature 600 degree centigrade
Above is for your kind information.thanks in anticipation
Best Regards,
M.Zafar Iqbal
03/26/2015 7:56 AM
A general rule that is generally followed most of the time is if you let it soak for more than the designated time it will begin to burn off the carbon resulting in soft parts that will never get hard.
Here's a discussion on it from several years back.
http://cr4.globalspec.com/thread/67901/Carbon-Material-SA516-70-to-be-Normalized-and-Tempered
03/30/2015 1:37 AM
Depends on the atmosphere.
Re: Effect at Mechanical Properties due to Excessive of Time
03/25/2015 6:14 AM
It depends on the rate of formation of rust, Mildred.
Good moaning!
Re: Effect at Mechanical Properties Due to Excessive of Time
03/25/2015 10:29 AM
Register to Reply 6 comments
chzaiqbal (1); Crabtree (1); Just an Engineer (1); Massey (1); Torqued (1); truth is not a compromise (1)
