Previous in Forum: Handling 4 Million Litres of Argon Gas Per Day   Next in Forum: Hydrotesting of Shell & Tube Heat Exchanger
8 comments
Anchorage as Per API 650
04/04/2015 2:50 AM
Hi there!
Greetings..
I am designing a tank for worst seismic zone and having Dia=20m & Ht.= 18m (liquid ht=17.5). Through the calculation , i am getting the Anchorage ration, J= 3.8 and therefore Anchor bolt size is coming out to M56 (36Nos.).
The requirement is quite high and i am not sure about it. Please guide me if It is okay to have such a large size of bolts.
regards
Re: Anchorage as Per API 650
04/05/2015 10:52 AM
Only one bolt? Take more bolts use smaller ones? Strongly recommend to have another engineer in your company looking at this. Noone here will be liable if giving advice but you are. Also what exactly did you calculate? You haven't had any reply because no one sees what you have done.
Even it is a big bolt its better save than sorry.
Good Answers: 151
04/05/2015 12:06 PM
The OP stated 36 56mm (2-1/4 inch) anchor bolts around a 62 meter circumference. Anchor spacing would be about 1.75 meters. This does not sound unreasonable.
04/05/2015 12:51 PM
"36 nos" did not compute as numbers when flying over it. Anyway more than to say it sounds reasonable does not seem possible.
Good Answers: 151
04/05/2015 4:36 PM
I should have added, while the numbers appear to be reasonable thy may not be necessarily correct.
Good Answers: 102
04/06/2015 12:13 AM
That anchor spacing seems a bit long....can the OP recalculate with more anchors closer together and then possibly come up with a more common, smaller bolt size.
I haven't spotted foundation hold down bolts this big before, have I led a sheltered life?
04/06/2015 12:16 PM
A difference of words:
• Anchorage, a town in Alaska.
• Anchorage, a mechanical fastening device.
Hobbies - CNC - New Member
04/06/2015 2:25 PM
The size of the bolts is quite large. In Nevada the water storage tanks are set with no hold down bolts, the bottom is welded together onto a concrete pad with embedded steel weld anchors that are welded to the tank bottom as it is being fabricated.
I know Nevada isn't in a "Seismic" zone but I think your calculations are off.
Possibly the "seismic" values
Location: I come from the deep south but currently reside in the land of ice and snow, midnight sun and all that crap
04/07/2015 2:53 AM
The anchor bolt requirements do not sound that unreasonable. We have done projects in Chile where they have pretty substantial seismic requirements and we have in some cases put two circles of anchor bolts on equipment (one inside and one outside of the vessel skirt).
I would have a local civil engineer review the calculations as a sanity check and just to be sure.
Register to Reply 8 comments
70AARCuda (1); gringogreg (2); IdeaSmith (2); Original_Macgyver (1); Pulpmillguy (1); Wal (1)
