I work for a company that manufactures gymnasium equipment. Yesterday I became involved w/ a jobsite problem where the electrician claims that our winch assy (w/ 2 hp motor) is pulling 80 amps! The FLA on this motor is 20 amps. A couple of weeks ago, the problem was originally diagnosed as a low voltage problem...the relays/contacts were "chattering". Since then, the electrician claims that he has reduced the wire run 300 ft and changed the wiring (I asked several times for him to explain what he had done, and got a lot of "double-talk"). Everything was supposedly working properly until the end of last week. Now the motor, "makes a loud noise, like it's trying to pull itself apart".
Our winch assy consists of a Marathon motor bolted to a C-faced gear reducer and a "reversing" starter that consists of (2) Furnas 42BF35AF Controllers (relays) and (1) Furnas 48DA17A4 Bi-Metal OL Relay.
My questions are first (and most obvious) does anyone have any idea what could be causing this? Secondly, can 80 amps be measured, considering a 30 amp circuit is being used?
Thanks for your help!
Darvin
"Life is not a journey to the grave with the intention of arriving safely in one pretty and well-preserved piece. The intention should be to skid in broadside, thoroughly used up, worn out and defiantly shouting, "Wow! What a ride". -Unknow
