Previous in Forum: HAC   Next in Forum: Unbalanced Current
MV Neutral Grounding Resistor
04/21/2015 6:58 AM
Hi,
Can any one explain how to design NGR for 3x11KV ,2000 KVA DG's which is get synchronized.
How to find the NGR temp.withstanding capacity.
Regards
Murali
Good Answers: 445
Re: MV Neutral Grounding Resistor
04/21/2015 11:01 AM
Yes, there are people on the web who can, but no one should. You have not provided enough information for anyone to even guide you, and your questions indicate that you are doing your client/boss a disfavor by claiming you have expertise where none is evident to those who do. Any errors that you make will result in downtime, damage to property and possible loss of life, for which you will be personally culpable
Use your favorite search engine to find an electrical engineering consultant located near you, pay the price, and sleep well knowing that you did the right thing.
04/21/2015 12:09 PM
Good Answers: 42
04/21/2015 1:32 PM
First of all you can study ANSI/IEEE Std 32-1972 or IEC 60076-6[optional] .
If you intend to use an auxiliary zig-zag transformer see also[for instance]:
https://www.l-3.com/wp-content/uploads/2014/04/Georgia-Tech-Zig-Zag-Grounding-Transformers.pdf
And then when you will know what NGR you will need you have to choose it from a suitable manufacturer catalogue.
However, it would be better if you could directly phone a suitable manufacturer at first.
See[for instance]:
www.postglover.com
or
http://www.cressall.com/neutral-earthing/
or else.
Julius
Register to Reply 4 comments
7anoter4 (1); Anonymous Poster (1); RAMConsult (1); SolarEagle (1)
