Previous in Forum: Size of Start Capacitor of Central Heating Pump - Is It Critical?   Next in Forum: Lathe Cuts as Tool is Wound Back
Hazardous Environment Products
04/23/2015 1:36 AM
hellooo..
i came across a project, which has to be done for a oil and gas industry.its a duel fuel kit .In the gas train part of this project there is PRV, gas filter, solenoid valve. i got the PRV and solenoid valve with the atex certification for zone 2 ..but i couldn't find atex certified gas filter.
And am not sure whether the gas filter needs to be atex certified or not .
can anyone please help me out of this ...
thanks...............
Pathfinder Tags: Gas filter
Re: hazardous environment products
04/23/2015 2:32 AM
You just bumped into this and its not of real relevance for your income you say?
Well here is a link to read.
http://www.siracertification.com/atex.aspx
It would make sense to get familiar with the certification details.
Wiki is a good source too.
If you just research a while longer you might find things like this.
Feel free to digest and ask additional questions.
Hobbies - CNC - New Member
Re: Hazardous Environment Products
04/23/2015 11:15 AM
Sooooooo....... You just tripped over a job at a refinery and don't know what the regulations are?
Talk to the SAFETY MANAGER, they will give you a book about 6" thick that you need to know to work there!
Don't let this happen!!
04/24/2015 12:20 AM
Does the gas filter in question even need to be certified? I don't know given the limited information provided.
Have you tried an internet search for suitable filter manufacturers and ATEX certification?
In addition probably a good idea to get a hold of the applicable hazardous area standard relating to the equipment in question (again not sure exactly which one you need). A quick search on one of the standards websites (IEC?) should help.
Otherwise contact a hazardous area inspector or suitable filter supplier and ask them what they think.
Oh, and don't try and perform the selection and/or installation work if you are not suitably qualified. Unpleasant things could result (such as nasty legal things).
Good Answers: 102
04/24/2015 1:57 AM
Quick google found some Atex certified filters. So not sure why you couldn't find any....
Anyhow, whether or not a component like a filter needs to be Atex certified is, apparently, a gray area if you read into it a bit more. (OP can read I'm sure...)
So, if in doubt go for the certified filter or get one that isn't and $pend the time to get it certified..
Good Answers: 122
04/24/2015 9:40 AM
Not sure where your personal responsibility starts or ends but I would never consider accepting the risk and liability associated with not installing any device in a class 1 div 1 that does not meet the applicable code requirements.
If the code requirements are not clear and concise I would opt for the highest safety rated device(s) available.
A brief internet search yielded that there are multiple ATEX certified filters available.
04/25/2015 2:33 AM
Yes, it does.
Here, let me help.
Just copy and paste this.
Register to Reply 6 comments
IdeaSmith (1); jack of all trades (1); lyn (1); Original_Macgyver (1); SHOCKHISCAN (1); Wal (1)
