Previous in Forum: Calculation on a 3 Phases Unbalanced Delta   Next in Forum: Shielding MV Cables
Lighting Protection
04/25/2015 8:18 AM
Dear All,
For new lightning protection is it necessary to connect to exiting lightning protection?
Any advise.
Regards
Good Answers: 42
Re: Lighting protection
04/25/2015 11:24 AM
If both lighting protection systems are located in the same building-or at least 3.6 m apart-then you must. See, for instance, NFPA 780 ch.4.14 Common Grounding.
If they are not, in my opinion, still it will be better to do so
Julius
Re: Lighting Protection
04/25/2015 7:31 PM
Read the local codes.
Follow them.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
04/27/2015 12:38 AM
1. what does the client or your employer want? discuss the situation with them. make them happy.
2. I know NFPA requires lightning for "all structures." BUT...... if its a single story building in a low - lightning area, not storing explosives or combustible materials, common sense ALSO applies.
BSEE but always learning
04/27/2015 3:37 PM
What's the lightning protection exactly? What standard are you working to? What's the building and site? What's the existing protection consist of?
Please provide more information.
1capybara (1); 7anoter4 (1); jack of all trades (1); lyn (1)
