Previous in Forum: Sound Traveling Faster Than C?   Next in Forum: Extreme Accuracy Tasked Ordnance (EXACTO)
18 comments
Electrical / Circuit Tester/ Tracer
04/29/2015 10:08 AM
Hi, I have a question: First let me explain the typical scenario. A customer will call and tell me that they need a new swamp cooler installed / or the swamp cooler needs to be repaired. The neighborhood handyman has already been there first and has disconnected the wiring going into the cooler and the wiring coming from the switch, but has not applied wiring markers / terminal markers to the wires.
Then I have to scratch my head and say, " OK, what wire. goes to what ", so I follow the process, turn off circuit breaker ( sometimes a cooler will have its own dedicated breaker, sometimes it will share a branch circuit) . I get a 9 volt battery and attach (-) to ground ( green ) and (+) to a wire ( any wire). Generally the wiring is not too complicated, white-neutral , green-ground, black-L1 motor, red-L2 motor, black or orange or yellow circulation pump motor hot.
Here is the issue: The cooler is mounted on the roof, so I have to go up and down the ladder or through the roof access hatch a dozen times or so to trace the wiring.
Is there a type of circuit tester/ tracer I can get to make my job easier/quicker. I am trying to work smarter, not harder.
Thanks, Tonyhemet
P.S. I am not sure why when I post a question, it always shows up as Anonymous Poster # 1
Good Answers: 44
Re: Electrical / Circuit Tester/ Tracer
04/29/2015 10:11 AM
...the HO/neighbor's kid
less expensive than:
Circuit Mapper Breaker Identification System - 42 Circuit
http://www.mitchellinstrument.com/circuit-mapping-system.html
Good Answers: 102
05/02/2015 3:51 AM
That widget would do the trick.
04/29/2015 10:36 AM
Label the wires with letters, tie them together in pairs, go to roof and check continuity, mark the wires with numbers, and tie the continuous pairs together, go back downstairs and untwist the wires and switch the wires that were tied together with other wires, and test for continuity, now go back to the roof and repeat process....Draw diagram with letters on one side and numbers on the other side and as you determine each wire draw line from letter to corresponding number...switch numbers with proper letter to mark wires on roof...
Reply Score 1 for Off Topic
Good Answers: 92
04/29/2015 12:09 PM
Depending how often you do this and how many wires there normally are, I'd suggest take a handful of AA batteries and make up cell packs with them- you can even put gator clips on to make hook up easier.
Use 1, 2, 3, 4, and a 9 V (giving approx. 1.5, 3, 4.5, 6 and 9V), hook them on, mark the wires (recording which are which!!), and then go and check voltage to ground. This lets you ID up to 5 at a time for a the cost of a pack of batteries, some scrap wire and a roll of electrical tape.
Reply Good Answer (Score 4)
04/29/2015 1:32 PM
I like the idea, but not sure if the measurement of 1 or 2 volts differential is reliable working with dirty wire connections in the field....might be worth a try...
Good Answers: 69
04/29/2015 2:41 PM
Been there, done that; it works great, even the single cell circuit if you clean or scratch the copper. G.A.
04/29/2015 1:52 PM
Why not get a bunch of different valued resistors: start fairly high so that you can ignore any problems with bad contacts and wire resistance: say
1K, 1K5, 2K2, 3K3, 4K7, 6K8, 10K, 15K etc.
Connect all resistors together at one end and connect that end to the earth wire;
connect the other end of each resistor to one of the wires;
Go to the roof measure the resistance of each wire to the earth wire.
04/29/2015 5:18 PM
I like JNB's idea, but he beat me to it, solder some wires to batteries connected in series. Or hire a kid to help.
You have to register or you get listed as AP#1. If you've registered, make sure you're logged in.
04/29/2015 5:30 PM
Thank you, I never thought about different voltages for different wires. I bet Mac Guyver uses this method all the time !
Good Answers: 225
04/30/2015 12:04 AM
If, as you describe, the wires are of differing colours, can't you simply check what they control in the device and then make the switch sequences compatible, or alternately make the device connections compatible with what the switch is doing? No need for any wire tracing.
If a couple of wires are the same colour, then tie each of them to another differently coloured wire and then a simple check for continuity of the pair will tell you all you need to know.
If all wires are the same colour, then you can use resistors as described below to differentiate between them.
1. Choose one wire as your reference base - you will need to find both ends of that first - or you can even use an existing earth on the unit and jumper to a GPO earth or similar at the switch end.
2. Connect resistors of different sizes between the reference and each unidentified wire - for instance, my own tester that I used for similar purposes has 560, 1.2k, 3.3k, 5.6k, 8.2k, 12k and 18k etc. Ohm resistors mounted on a board. One end of all resistors are joined together and connected to an alligator lead, and the other end of each is equipped with its own alligator lead to connect to the wires to be tested. Number the wires and take a note of each connected resistance.
3. Go to the other end and measure the resistances between each wire and the reference to find which is which, compare the results with your notes and number them the same as the other end and the job is done. You will need to disconnect the wires at both ends to ensure no cross connections and thus faulty indications.
Good Answers: 225
04/30/2015 12:06 AM
Ahh that's what happens when you respond without reading all of the other posts... I see that this method of testing has already been mentioned.
GA to Randall, and I can attest to the method as being very efficient.
04/30/2015 10:38 AM
Yes. -- JHF
04/30/2015 11:20 AM
The resistor method is a good way, but you don't really need them if your wires are long and your meter has an accurate low ohms scale.
Twist one end in pairs. Go to other end and twist this end again in pairs except two.
Connect meter to one of the non-twisted wires and read the ohms to each twisted set of wires on that end. The readings will increase as the length of the wires goes up. Using a set of alligator clips helps the reliability of your readings. Write down the readings and mark them in order of readings
No resistors and no batteries! Just basic series resistance theory.
Bill H.
04/30/2015 3:12 PM
This looks as though it might work with a lot of messing about, but, at the moment: I'm a bit confused.
When you get to the top you can easily sort out which pairs are shorted at the other end, and so you can easily short one of each pair to the next pair to make one continuous conductor. But after you make your first reading (the resistance of one pair from top to bottom and back) you can predict exactly what all the other readings will be, and, therefore the readings are not really telling you anything.
And you still can't correlate the pairs at the top with the pairs at the bottom.
Good Answers: 225
04/30/2015 3:18 PM
I can't see how that would work...Perhaps you can explain it a bit more thoroughly.
Good Answers: 102
05/02/2015 3:38 AM
The different applied Vs and Rs to each conductor is a great way of giving each a signature.
Alternatively have different music sources connected to each and sort them out by melody with a speaker probing the other end.
Non invasive cable tracers work real well too. Get a few with different tones.
Rent an apprentice........
Good Answers: 54
05/02/2015 5:11 AM
I have a great idea that your client will love. Take the swamp cooler off the roof, cover the hole and patch it. Then install a new style window unit, such as the Bonaire unit (Home Depot sells two different sizes).
Your client will love how well the unit works and they won't have calcium marks dripping down the roof.
And, you don't have to worry about which wire to hook up.
05/02/2015 10:45 AM
In response: I appreciate all of the good answers, they are very helpful.
In reply to the last post: Yes, I have installed the Bon Aire Durango, Quality Australian Engineering. It would be nice if that company would export their down draft unit with the enviro wing here.
Methods to reduce or eliminate scale dripping on clients roof. All evap coolers have an overflow drain, the purpose of the drain is to remove water from the reservoir basin in the event the make up water supply metering valve malfunctions. Some down / side / up draft coolers are constructed from separate individual pieces, such as where the reservoir basin mounting flange is lower than the blower assembly mount flange, if the metering valve malfunctions, water can be drawn into the plenum venturi through capillary action or intake pressure while the blower is operating ( Trade wind TC 451/471/ for example) . With respect to the Trade wind, it is necessary to adjust the overflow drain riser so there is a 1" gap between the top of the overflow drain opening and lower than the basin flange in a horizontal plane.
Here in California we use drip watering systems, these water distribution systems use black polyvinyl tubing and 1/2" compression fit connectors ( sold at home depot etc. ) . Simple fix here: you will need a hose adapter fitting, a 90* fitting and a length of tubing as required for your application, Screw the hose adapter to the threaded portion of the overflow drain underneath the cooler ( use PTFE paste) , then a short length of tubing, then the 90* , then a length of tubing as required to the roof gutter/drain ( easy weezie) . I think this looks more professional than using a cutoff garden hose.
Reply to Forum Thread 18 comments
Autobroker (1); Bill H. (1); Circuit Breaker (1); cuba_pete (1); JNB (1); Randall (2); Rixter (1); SolarEagle (2); spades (3); tonyhemet (2); Wal (2); Yahlasit (1)
