Previous in Forum: Flushing of new pipe line   Next in Forum: calculation
Sea-Fastening and Pad-Eyes
07/14/2007 3:04 AM
So do you have any website / advise...whatsoever regarding sea-fastening ?
do you have any advise about the stiffness of pad-eyes ? ie how stong a plate with a certain thickness can be ?
lets say a steel plate with 13 mm thickness and certain dimensions. how much impact can it hold ? what is its minimum breaking load ?
you dont have to go in depth if you dont feel the need to ...just pin point the important points or sites codes....etc.
i know its a structural question so maybe the user STL Engineer would be of help.
however, please dont bother and bark at me for asking this. between (), you dont have to be worried...as all these questions i ask are for my information...decision analysis and studies have been already made and approved by more qualified people.
regards
Good Answers: 40
Re: Sea-Fastening and Pad-Eyes
07/15/2007 10:13 AM
Sounds like you are starting from scratch, here. What are you building? Specifications change as the years go by, and new metallurgical/corrosion knowledge is gained, but for an off-the-wall example Bridges typically use(d) ASTM grade A36 steel exhibiting a yield strength of about 36,000 lbs/in2.
If you're referring-to structures such as offshore steel platforms associated with oil & gas production, the API Pecommended Practice RP-2A(WSD) ...{Working Stress Design}... provides a wealth of such knowledge, while heavily referencing the AWS D1.1 Structural Welding Code for attachment specifics. Anything "structural" in the offshore realm will mandate full-penetration welding (no fillet welds, and absolutely no skip/intermittent welds!). These documents can be bought online.
If you're referring to Ships, drilling rigs and such,
visit the American Bureau of Shipping's site:
http://www.eagle.org/ (click "Rules and Guides" at the top, then "Common Structural Rules")
this will take you to:
http://www.eagle.org/prodserv/applications/csr/index.html
where you can download demo software.
As far as how thick or stiff a given pad-eye should be, that depends on it's purpose. Those used simply for hanging appurtenances are much smaller (and less 'stiffness required') than those at the top of an offshore platform's legs, used for lowering it to the seafloor, and then lifting it back out again.
Hope this helps at least somewhat... Best wishes ~
You might be interested in: Pad Eyes, Thickness Gages, Eyewear
