Previous in Forum: 33 KV Power Line   Next in Forum: PT Connection on Relay is Removed
Metering
06/11/2015 9:27 AM
I need to know how to calculate the losses if p1 of a CT is placed in opposite direction.
Again, i want to know how to calculate losses in a shunted TTB.
Finally, if R,Y,B are 800A respectively, how do we calculate the required meter and transformer for such a customer if on 33kv and 11kv.
thank you all
Good Answers: 140
Re: METERING
06/11/2015 9:51 AM
How? By doing it according to the metering standards of the utility that supplies the energy. If this is a non-utility revenue issue, then according to what the electrical engineer who designed the system has put down on the plans for this service.
Good Answers: 69
Re: METERING
06/11/2015 9:55 AM
Google substation calculations, you will get many results, download a couple .pdf's and then do a text search thru all of the files containing your key words (TTB, CT etc.).
Good luck
Anonymous Poster #2
Re: Metering
06/11/2015 11:14 AM
I had a TTB. The wheel fell off.
Re: Metering
06/11/2015 7:47 PM
You don't calculate the losses or the required meter.
That responsibility must fall to a duly qualified electrical engineer, using the applicable codes and specifications for the project.
Anonymous Poster #3
Re: Metering
08/10/2023 5:17 AM
Anonymous Poster (2); lyn (1); North of 60 (1); Yahlasit (1)
