Previous in Forum: Mechanical Engineering Reference Manual for PE Exam   Next in Forum: Fastner Material Nut for ASTM A193 Gr B16 Stud
Australia - Member - New Member Pakistan - Member - New Member Engineering Fields - Automotive Engineering - New Member
Vaccum Creation
06/18/2015 2:46 AM
How to create vaccum through conduction,convection and radiation...
be sincere to your work...
Good Answers: 137
Re: Vaccum Creation
06/18/2015 5:37 AM
You can't. And it's vacuum.
Good Answers: 38
Re: Vaccum Creation
06/18/2015 9:04 AM
Vacuum can be created through conduction,convection and radiation only when heat transfer is carefully managed.
There have been several recent research papers regarding these new methodologies and they have been published in the American Journal of Physics as well as the esteemed ASME Journal of Heat Transfer.
The process is not efficient and therefore expensive.
Mechanical generation of a vacuum is still far superior and less expensive.
Re: Vaccum Creation
06/26/2015 1:37 AM
Sir can u define the way how to create vaccum through conduction convection and radiation. If u provide me a good theory with example then i will remain thankful to you thanks
Hobbies - CNC - New Member
Re: Vaccum Creation
06/18/2015 10:42 AM
Why would you want to create vacuum using those inefficient methods? Use a vacuum pump!
Register to Reply 4 comments
Codemaster (1); MJCronin (1); Original_Macgyver (1); user-deleted-1071 (1)
