Previous in Forum: Civil Engineers   Next in Forum: Industrial Valve Design Services
Zirconia Ceramic Components
07/09/2015 6:03 AM
Zirconia ceramics materials provide excellent erosion, corrosion and abrasion resistance along with temperature resistance, fracture toughness and strength. These ceramic components are used in extreme service applications that take advantage of their superior wear and corrosion resistance.
FUBOON offers Yttria Tetragonal Zirconia Polycrystal(Y-TZP), there are many applications of Zirconia ceramics in the chemical and petrochemical industries. They provide economic payback in the way of reduced maintenance and down time. Zirconia ceramics is also becoming the material of choice for components in healthcare applications.
This dense advanced ceramics material is usually precision ground using conventional diamond cutters and wheels. Machines used for precision grinding include:
Surface grinders
CNC milling machines
Jig grinders
Center less grinders
CNC lathes
ID grinders
The types of dense, advanced ceramic components produced by FUBOON include:
Ceramic Valve components
Ceramic Pump liners
Ceramic Roller
Ceramic Plugs
Ceramic Sleeves
Ceramic Pistons
Ceramic Nozzle
Precision ceramic balls
Ceramic Spools
Ceramic Shaft
Ceramic Press tooling
www.fuboon.com,ceramic pump,precision ceramic balls,ceramic knives,ceramic tube,ceramic discs,all fine ceramic products.
Pathfinder Tags: Zirconia Ceramic components
Re: Zirconia Ceramic Components
03/30/2016 11:38 PM
Can be produced according to customer's drawing.
06/08/2016 4:25 AM
we produce Zirconia Ceramic Components as your drawing requirement.
08/11/2017 3:11 AM
Register to Reply 3 comments
