Previous in Forum: 220v-12v Logic Gate   Next in Forum: Copper Plumbing Failure Due to Broken Neutral?
Magnus Effect
07/18/2015 10:12 AM
I wondered about this when Cousteau had one of his ships fitted with the setup.
https://www.youtube.com/watch?v=2OSrvzNW9FE
Re: Magnus effect
07/18/2015 10:40 AM
Same effect that makes your drives slice to the right or hook to the left. Ball spin. The ball always travels in the direction of the spin.
That's why good golfers mostly want to put pure backspin on their golf shots. It's a thing of beauty, if you're a golfer.
Re: Magnus effect
07/18/2015 11:32 AM
Re: Magnus effect
07/18/2015 11:46 AM
Zip grooves chew the balls up too badly. Especially the Balata covers.
Re: Magnus Effect
07/18/2015 7:55 PM
An easy way to demonstrate the Magnus Effect (if you can't make it to Hoover Dam) is to throw a beach ball with backspin. You can easily see the upward deflection.
Re: Magnus Effect
07/20/2015 6:56 AM
Another easy way to demonstrate the effect is by making this simple toy.
You just need the cardboard tube from the middle of a toilet roll, some tape and an elastic band.
Make a "hook & grip" from the tape by folding it
and cutting a small notch,
and, stick it to the tube: you may need some extra tape to ensure it holds firm.
Launch the thing by holding the grip under the tube and "catapulting" it the way you would "fire" anything else with an elastic band:
Made with a cardboard tube like this they "behave" quite well: normally they'll curve upward 'til they stall then drop, but curve away again so that they "land" fairly flat.
But, if you experiment with longer smaller diameter tubes made from paper they can perform all sorts of acrobatics.
Don't expect any long flights though: I must try out a 2 litre drink bottle some time.
Fredski (1); lyn (2); Randall (1); Rixter (1)
