I would like to know why it would be necessary to use mixed insulator
strings for instance glass/porcelain or glass/polymeric or
polymeric/porcelain combinations in high voltage insulators of overheard lines. How
are these combinations usually connected up parallel/series does this
improve the voltage distribution in any way as compared to insulator
strings of the same kind? does this improve the electrical characteristics
of the whole combined string? another question, beside using the
voltage distribution method to locate the faulted unit in the insulator
string, what other information can be obtained from analysing the voltage
distribution across and insulator string?
I know the differences between the different insulators my question is why
would you use combinations of the insulators mentioned above as opposed
to having insulator string of the same material. Pls help!
