Previous in Forum: turbulent flow of water   Next in Forum: New Alternate Energy Technology
10 comments
Vibration Isolation
07/18/2007 5:34 PM
Did you know or do you care that there is a product that isolates vibration from clothes washers (any brand) and many other appliances?
Popular Science - Cosmology - New Member United States - Member - New Member
Re: Vibration Isolation
07/18/2007 9:36 PM
Most washing machine tub assemblies are mounted on springs/shocks. As long as the load is somewhat balanced, the outer frame/housing doesn't exhibit a lot of vibration. Without the spring/shock mechanism, if the spin cycle began with a severely unbalanced load such as, say, a single blanket or something that winds up on one side of the tub, the machine could actually damage itself.
-John
All worthwhile programmers know that constants always vary.
07/19/2007 9:57 AM
There is also usually a large lump of something to add some mass. In some machines, it is a cast block of concrete!
Good moaning!
07/19/2007 3:10 PM
Or a thick cast iron base.
Good point!
07/19/2007 3:42 PM
But my original point is that vibration exists regardless of how the machine is built and there is a solution that eliminates the transfer of the vibration and noise from the machine through the house.
What would it be worth? $250, $200, $150, or less?
07/19/2007 4:57 PM
Hi Mike,
For me personally, "less" (read: $0)! My washing machine rests on a solid concrete floor in my basement. Believe me, there's no vibration through my house. Same for dryer.
Now, for someone with such appliances residing on flooring/joists with a propensity to vibrate, I suppose there could be a market for an isolation device.
-John
07/19/2007 5:02 PM
The isolator does not replace anything inside the machine. The machine sits on the isolator.
09/11/2007 11:25 PM
Hi Mike,
You are providing vibration isolation services or want these services?
09/12/2007 5:47 AM
A decent quality washing machine in a decent quality house doesn't present much of a problem in my experience. If people buy bargain machines they might appreciate a device to reduce it after realising their mistake. I suspect most people with a memory would spend more on their machine next purchase or ask around more but hopefully you're stuck with the first one for a good number of years. In the kitchens I know there's zero under-worktop clearance for anything other than a cigarette paper. How much would this thing add to the overall height?
As buildings get cheaper and more densely packed, or in multi-storeys there may be more of a case. We have already, IMO, something of a noise pollution problem (certainly in southern UK). So I would applaud anything that helped but must say I donn't think such a thing would occur to me as a high priority.
Stop the danged military aircraft flying over my house at 250ft at midnight and the equally danged recreational aircraft, especially helicopters, at other times; that'd make me happy. Danged if I'd feel I should pay toward their removal though.
Wish I was here more often.
Good Answers: 143
09/12/2007 11:54 AM
Go to
www.mcmaster.com
They've got a ton of isolators, some even inexpensive. You should get by with one of the pad types. If you need springs or a bladder, you got something wrong in that machine or else your wife has to stop washing the Sheltie in there.
Tom
03/23/2008 10:59 PM
I would try a set of pads for your machine I have tried several having a very similar problem. I tried the several isolators. Probably the best set of pads I have experience are from a company called "The Vibration Solution" they make Silent Feet (www.thevibrationsolution.com), great for isolating that high frequency vibration. The reason I liked their pads more is that they use a material that also isolates things for the military NASCAR and NASA (browse around on their page for a sec). But their material is better because unlike a lot of the competitors that use a "Styrofoam" like material that will break down during uses and loose isolation properties the Silent Feet will not. Worth giving it a shot hope that helps
Register to Reply 10 comments
Crabtree (1); Johnjohn (3); MIKE@MMATECH.COM (2); Nattone (1); TVP45 (1); wash (1); Wrenched (1)
