Previous in Forum: Your Tax Dollars At Work Causing Disasters   Next in Forum: What is This?
12 comments
Freeze Resistant Livestock Waterer
08/09/2015 4:02 PM
Hi All, I was wondering if anybody has a diagram / suggestion on how to construct a freeze resistent livestock waterer using ground heat instead of electric . years ago ,a rancher described a system he built using a large concrete pipe [3 ft ] installed vertically about 5 ft deep , set a tank on top, both the perimeters of the tank and pipe were insulated , and the open top of the tank was partially insulated with a hot tub floater blanket. With the adding of water on a regular basis , this seemed to work ok depending on how much water was added and how severe the weather In my case , there won't be much water consumption, but installed inside of the barn ,so there won't be wind issues , I'm thinking of installing a 12v valve in the ground heat pit and over flow drain to add water on a timer to suppliment ground heat and keep water fresh If anyone has any ideas that could lessen the learning curve on this project I would be thankful
Re: freeze resistant livestock waterer
08/09/2015 4:24 PM
There was an extensive discussion about this 2-5 years ago.
Here ya go:
Need Help in Keeping Water Tanks Open
08/10/2015 9:05 AM
Thanks Lyn , This "extensive discussion " was very helpful
08/09/2015 4:34 PM
I would lay down a large coil of polyethylene tubing and build a large compost pile on top of it at the beginning of every winter....try to build the tank and tubing in a relationship that would promote natural convection for circulation...or a very small pump....
http://www.motherearthnews.com/renewable-energy/compost-water-heater-zmaz81jazraw.aspx
Good Answers: 120
08/09/2015 7:29 PM
one of the problems is the maximum density point of water = 4C, which is why lakes freeze on top and do not "turn over".
I would imagine a deep tank of brine, buried below 4 feet deep that allows warm brine to rise and heat the water in the tank, which should be insulated as well. The underground brine tank needs to be large enough to gather heat in the face of the freeze. Obviously, this would only work for mild freezing so the capacity of the earth to warm the above ground portion - these sizes can be worst case designed.
Less severe climates have a smaller burden
Per Ardua Ad Astra
08/10/2015 9:29 AM
This is for a livestock waterer.
I don't thing you can get livestock to drink briny water, or keep them healthy if they *DID* drink the salt water.
Good Answers: 120
08/10/2015 9:36 AM
No, the brine is used as a heat exchange medium to the deeper earth.
The stock drink pure water.
Per Ardua Ad Astra
08/10/2015 9:50 AM
Ah, re-reading your post, I spotted the point where you mentioned a second tank indirectly.
That makes a lot more sense, it's just with everyone else talking about single-tank solutions, using just two words within a sentence to indicate a second take can be a little too subtle for some.
Good Answers: 16
Re: Freeze Resistant Livestock Waterer
08/09/2015 11:18 PM
What is the ambient temperature?
I am thinking of an ice cracker that works with levers activated by the weight of the animal on a platform to break the surface ice.
Temperatures below freezing are rare here but I did see a frost just last year.
BAB
Make it so.
08/10/2015 5:30 AM
Dig a pit under the desired location,and put in about 4 layers of baled hay.
Put water tank on top of the hay bales.
Unless it is super-cold,this will prevent freezing.
Replace the hay every fall. Simple and natural.
I used to leave a bale of hay in the back of my jeep during the winter to prevent the
windshieled from icing up.
08/10/2015 11:36 AM
My water tank is surrounded by a plywood box filled with hard foam insulation. I had an uninsulated tank outside and the insulated one inside (no heat just out of wind.) The one outside would get an inch of ice at night, the inside insulated one just a thin film. So no matter what you use insulate it well even if you end up using a tank heater it will save you at least half.
08/10/2015 12:06 PM
justthe cowboy what is your location and climate Thanks
08/10/2015 1:51 PM
I'm in NE PA. I use a 125 gallon tank. Last winter -10 to +32 deg nights. I was amazed at how well it worked, I wasted alot of money before when I used a heater.
I will be putting a heater in the tank this year because the vet suggested if for the older horses, he said they drink more when the water is not at 32 deg.
Register to Reply 12 comments
adreasler (2); aurizon (2); BlueAussieBoy (1); HiTekRedNek (1); Jazzman (2); justthecowboy (2); lyn (1); SolarEagle (1)
