Previous in Forum: Have You Seen This?   Next in Forum: Looks Like Apple Wants to Sell You a Car
17 comments
What Is This?
09/16/2015 6:26 AM
I found this while hiking around some rocks and brush in central Africa. The other pictures didn't come out so well but there is a small hole (about 2-3mm)at the lower end and it appeared that the fine grass or stems of something were protruding out at an angle. It was impressive miniature basket weaving. Just wanted to know if anyone had seen these before and knew what magnificent creature built it.
deanpavil
Re: What Is This?
09/16/2015 6:50 AM
Only thing I've seen like it is the case of a caddisfly larva. Never as neatly constructed, tho'. Some of the images in this search are vaguely similar:
https://www.google.co.uk/search?q=caddisfly+larvae&biw=800&bih=528&source=lnms&tbm=isch&sa=X&ved=0CAcQ_AUoAWoVChMImurxs6_7xwIVRdsaCh3IcQyC
Good Answers: 61
Re: What Is This?
09/16/2015 7:43 AM
That was my first reaction too. I've seen them with light brown coloured tubes around their bodies - made from what, I do not know. Also some use pieces of gravel stuck together to build a suit of amour. Fiendishly clever and done with a brain the size of a pinhead. Nature is truly marvelous.
Re: What Is This?
09/16/2015 8:26 AM
A really tiny Jenga game?
Re: What Is This?
09/16/2015 9:06 AM
I agree that this is likely an insect case for a complete metamorphosis transformation. I suspect a moth or butterfly of some kind. Nature's engineering is truly impressive. You should look for an African entomology web site or forum to get this identified.
Good Answers: 266
Re: What Is This?
09/16/2015 9:37 AM
Possibly a bag worm. That one sure had some skill. Most I've seen are not that neatly put together.
Re: What Is This?
09/16/2015 9:55 AM
wild guess, a cocoon
Re: What Is This?
09/16/2015 10:27 AM
Interesting thing is Caddisfly larvae don't make them to pupate - they make them to live in, in the same way a snail uses its shell.
Re: What Is This?
09/17/2015 12:07 AM
I came across these caterpillars that look like snakes when viewed head on....very clever....
Good Answers: 61
Re: What Is This?
09/17/2015 4:06 AM
Incredible!
Re: What Is This?
09/16/2015 12:49 PM
There must be a very uniform building material at hand for such a uniform cocoon....probably some species of bagworm...
found this..
Good Answers: 97
Re: What Is This?
09/16/2015 1:39 PM
BAGWORM! I got shrinkage just thinking about it.
Why is Kunta dancing? "He has a bad case of bagworm."
CRTL-Z
Re: What Is This?
09/16/2015 5:32 PM
It would be nice to see more pictures showing more detail....I would like to see this structure in a 3-D program....maybe you could get more closeup detail with a better lens setup...
Re: What Is This?
09/16/2015 6:23 PM
Suspect it's a bit too late for that.
Good Answers: 109
Re: What Is This?
09/16/2015 9:36 PM
Its a Bagworm.
Re: What Is This?
09/17/2015 12:49 AM
Definitely not a fractal
The doctor said "just one post or reply aday in CR4, take it or leave it". I said, "what does that mean?"
Re: What Is This?
09/17/2015 1:30 AM
Thanks folks, for the interesting finds and information.
Yes, unfortunately that artifact never made it out of the bush but i am watching out for more.
deanpavil
Re: What Is This?
09/20/2015 7:23 AM
Around my yard i have found many of these;
As you can see the top one still has an inhabitant munching on some Lippia. It is also very similar to the type you found. They are on the ground in the grass. The bottom one has the sticks running longitudinally, with one being extra long for the moth/butterfly to stand on to dry its' wings. The location is on the coastal plain on the western edge of Australia.Jim
Register to Reply 17 comments
Brave Sir Robin (1); deanpavil (1); energyconversion (2); Fredski (1); IdeaSmith (1); JIMRAT (1); JohnDG (3); Legolaz (1); ozzb (1); redfred (1); SolarEagle (3); Unredundant (1)
