Previous in Forum: Eddy Probe Side View   Next in Forum: Car wont start.
Ex Equipment Code Application
09/18/2015 1:41 AM
I know we may refers to Hazardous area classification for Ex application, but How to justify ATEX (EX) equipment code application?
Eg:
Junction box for 120VAC instrument at ZONE 1, what type of Ex JB to be installed? Ex e or Ex d?
Ex e (indtended to prevent a potential ignition arising)
Ex d (Intended to prevent an ignition from escaping outside the equipment)
What i think is Ex d can cover for Ex e and Ex i, isn't it?
Good Answers: 97
Re: Ex Equipment Code Application
09/18/2015 12:40 PM
"Whatever method of protection is used, there are always limitations on the
level of protection offered in environmental terms. Any exceptional
circumstance will not necessarily be covered by the certification, and
engineering judgement has to be exercised. Some of the factors to be
considered are:
Temperation - either extreme
Exposure to water - incl. condensation
Vibration and impact
Corrosion
Chemical activity - particularly affecting choice of cable
Exposure to ultra-violet rays or other radiation
Intrinsic safety is in general less influenced than other techniques by these factors, but
their extremes could result in certification not being valid, and occasionally an installation
could become dangerous. In comparison, it is quite obvious that a flameproof
enclosure half full of rusty water being electrolyzed to hydrogen and oxygen is not safe.
In practice, there is not often a major problem, but blind faith in certification can lead to
difficulties."
CRTL-Z
09/18/2015 12:42 PM
your training will have already shown you that you can use either of those in zones 1 and 2. It should also have made you aware that there is no such thing as an ex I junction box!
Did you sue the training provider, Mildred?
Good moaning!
09/20/2015 3:09 PM
Which standards are you thinking of, or do you mean Ex ia/ib under European ATEX and IECEx standards?
09/20/2015 3:04 PM
Yes for a junction box Ex e is fine and common under European ATEX rules as long as the junction box and terminals are Ex e ATEX certified.
Site preferences, consultants, environment, etc however may dictate the use of one protection method over the other regardless of if both comply, so you may need to check.
Good Answers: 97
09/25/2015 5:05 PM
Be careful, mentioning "Site preferences, consultants, environment, etc however may dictate the use of one protection method over the other regardless of if both comply, so you may need to check." may get you an OT. Like the one I got from some B-hole.
CRTL-Z
Good Answers: 116
09/25/2015 4:48 PM
Ex d may often be applied to methane, but is very limited for hydrogen. Ex i is widely applicable but restricted to low power. A method of protection is not applicable to any risk.
Register to Reply 6 comments
67model (1); Crabtree (1); jack of all trades (2); Unredundant (2)
