Previous in Forum: Air spring replacement   Next in Forum: increase head of the axial flow pump
Need source for "Rickwell"(?) pipe.
07/22/2007 10:31 PM
I am seeking a source and technical information as well as information on installation standards and techniques for pre-insulated steel piping for heating lines, to be installed underground. I am told there is a product called "Rickwell". I'm not sure of the exact spelling, but I was unable to find anything through a Google search that would provide any of the above information. If anyone knows of a distributor or wholesaler for this material or something equivalent I would be very grateful if you could share this information with me.
See Bio for signature line........political correctness and insecure people are such a pain-in-the-ass.
Good Answers: 27
Re: Need source for "Rickwell"(?) pipe.
07/23/2007 10:08 AM
It's actually RicWil and they still manufacture these kinds of pipes. Others are Tricon Piping Systems and Perma-Pipe.
Try your search again for Ricwil.
07/24/2007 1:30 AM
It is actually Rock Wool, a heat insulating material for pipes, heaters, heat exchangers, equipment, houses, ... etc.
Rockwool Ltd :: Home Rockwool UK - environmentally friendly stone wool insulation for thermal acoustic and fire protection of roofs, walls, floors and pipework in the home and ...
Rockwool Insulation, Polyurethane Insulation, Safety films ... Manufactures of Rockwool Insulation, Polyurethane Insulation, safety and security films. Income Rockwool Leaders in Thermal Insulation Technology in ...
GLASSWOOL & ROCKWOOL Rockwool insulation. Additional research studies .... glasswool and rockwool insulation after obtaining. the technology rights. ... Rock Wool Manufacturing Company, DELTA insulation.Manufacturer of DELTA insulation for Industrial, Marine, Commercial and Pipe Products.
Insulation Mineral Wool Rock wool Rockwool International, the Denmark-based parent company of Canadian insulation manufacturer Roxul Inc., announced to the Copenhagen Stock Exchange its ...
Good Answers: 19
07/24/2007 10:32 AM
RicWil, Perma-Pipe, and others are not "off the shelf" products, but actually customed engineered and produced based on specific project requirements. They will want to know the material being piped, design temperature, carrier pipe material, insulation material, shipping length requirements, etc. etc. etc. It is not necessarily the cheapest system around, but if properly specified it will last 30 to 50 years.
07/24/2007 1:07 AM
Try Rockwell [a US company] better yet, google search the item and its description.[try different search terms]
Good Answers: 19
07/24/2007 2:48 AM
I don't know about a supplier, but here is what "Rickwell" is:
"Rickwell systems are a way of insulating a pipeline that is essentially a pipe within a pipe with a layer of insulation between them. This presents problems, as when a leak occurs from the inner pipe, it may not escape from the outer pipe for some distance, which can lead to erroneous results."
That excerpt is from this article: http://www.irinfo.org/articles/article_3_2005_weigle.html
It sounds like this project is a bit large for DIY unless you have some really knowledgeable onsite help. Paying a consultant fee (or an experienced contractor, for that matter) could save you a bundle in the long run. Good luck.
Abdel Halim Galala (1); Anonymous Poster (1); Bluestone (1); bubbapebi (1); Ried (1)
