Previous in Forum: PLC Processor's Working Memory   Next in Forum: ITP for Instrumentation works
Level Transmitter
10/13/2015 4:08 PM
good evening guys,
can anyone tell me that may i install a dp type transmitter used for level measurment in a close tank above then its High tapping point n what about to install in line with low tapping point if it is a column having hieght more then its low tapping point. ur valuable answer can clear my stupid logic :-p thank you
Faizan
Re: LEVEL TRANSMITTER
10/13/2015 4:49 PM
The text of your post is unclear to me. A picture is worth a thousand words.
10/13/2015 5:24 PM
is it possible to calibrate if it is wet let n what will be in cause of dry leg?
Faizan
10/13/2015 5:51 PM
Do you have the operators, or installation manual?
A transmitter is less important than the sensor.
Name the brand and part number of the devices.
Re: Level Transmitter
10/13/2015 6:14 PM
10/14/2015 12:32 AM
You have logic, but you speak like an abstract test Could you find ways to rephrase what you wanted to ask, perhaps?
The doctor said "just one post or reply aday in CR4, take it or leave it". I said, "what does that mean?"
fazannaseem (1); Kilowatt0 (1); Legolaz (1); lyn (1); SolarEagle (1)
