Previous in Forum: Injection moulds   Next in Forum: diaphragm pump
tolerance
07/25/2007 6:56 PM
injection moulding,what should be the tolerance between an injection moulding barrel and the check ring of a 35mm. screw
Good Answers: 16
Re: tolerance
07/29/2007 10:55 PM
What is the material being injected and are there any fillers in it? What is the optimum opperating temperature for the cycling times you want to achieve?
Make it so.
