Previous in Forum: Axial Surface Condenser Support Type   Next in Forum: Actuator Stroke Timing Calculation
8 comments
Another Free Energy Device (Pakistani Invention)
12/30/2015 10:43 AM
I came across viewing this another free energy initiatives "Free Energy Self Running magnet".
It's very convincing but it has to do a lot of proof before it can be considered sane enough. It seems to violate the energy laws.
Pathfinder Tags: Pakistani Free Energy
Re: Another Free Energy Device (Pakistani Invention)
12/30/2015 11:03 AM
I'm sold. I've seen it with my own eyes and I am ready to invest $15,140.00 USMD.
This could revolutionize power generation.
Here's the proof that I'm serious.
LynDoor™Industries is always looking for new and revolutionary ways to improve the world.
12/30/2015 11:03 AM
I'm certain that this is just a well executed sham. Illusionists regularly make things that seem impossible. I see many places a battery could be hidden.
12/30/2015 11:15 AM
Fake. The two nails that get pounded into the ground are where the real electrical power is coming in.
He has some sort of electrical feed hidden in the dry ground under the device.
Also given the approximate load being carried and the slow RPM's that the device is turning at if the magnet motor was doing the mechanical work the torque on the little spring coupler would twist it to pieces as soon as the loads are turned on.
12/30/2015 11:31 AM
So, the "scientist" moves the contraption off a smooth, level surface onto the dirt and then drives two nails into the dirt.
Why can't you just believe that it's all on the up and up.
12/30/2015 11:30 AM
Why waste your time, there are 100's of these video's on line.....none of them work as advertised, they are all fake...magnets contain no energy, just a force field....some people just don't get it....the only material that gives off free energy is radioactive materials, unfortunately they are quite toxic to be around....
https://shschemistry1.wikispaces.com/Electron+Configuration,+Ion+Formation,+and+Radioactivity
12/30/2015 11:38 AM
the last motor I aligned was 125HP 3 PH to a 100ton Trane compressor. the shaft needed a dial indicator to be within 4 thou spec. I didn't have the luxury of using a stainless hose clamp
Good Answers: 181
12/30/2015 5:19 PM
Tool junky!
Use a wooden stick and a piece of string like the rest of us.
Good Answers: 61
12/30/2015 1:05 PM
After all those billions spent on nuclear fission and fusion - what a waste!
Register to Reply 8 comments
energyconversion (1); Fredski (1); lyn (2); redfred (1); SolarEagle (1); tcmtech (1); TonyS (1)
