Previous in Forum: Recycle I'm already doing it....   Next in Forum: Are you sober if you have no hangover?
Opto-isolated USB-interface
07/27/2007 5:51 AM
Hi all,
Is there someone who knows an opto-isolated USB-interface ? I mean a relative simple converter, no USB-to-PC-to-ethernet-to-opto-to-ether...... and so on-solution.
Thanks Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
Pathfinder Tags: USB opto-isolation
Re: Opto-isolated USB-interface
07/27/2007 11:38 AM
Can you explain why you need opto-isolators? If it's just electrical isolation, I'd recommend using one of the NVE magnetic isolator chips. Much better than optos. Transformer coupling - like is commonly used on ethernet interfaces - might be another approach.
07/30/2007 5:47 AM
Bhankiii,
yes, it`s "just" electrical isolation, but more than 5kV partial discharge free and with a low coupling capacity of <10pF. Those NVEs are only good for "normal" surroundings, not for HV applications. I found that those manufacturers often brag with isolations of thousands of volts but whwn you read the data sheet its only for 1 second or one minute and VDE approbations only allow use in mains applications up to 250V AC.
Thanks Uwe
07/27/2007 12:14 PM
Uwe,
Isolated converters may be found here.
http://www.bb-elec.com/tech_articles/the_usb_solution.asp
Sounds like you may be looking for a hub. That would be nice.
Luck, Duce
07/30/2007 5:48 AM
No, Duce, unfortunately they don`t have. Thanks Uwe
Register to Reply 4 comments
bhankiii (1); Duce (1); uweka (2)
