Previous in Forum: Wiring Diagram for a Thorn 42 CNC   Next in Forum: Ellipsoidal Head Thickness Calculation Inquiry
Decoupler on HHW System
01/11/2016 3:33 PM
I've used decouplers on large HVAC systems in the past, but I am having an issue with one installed on a smaller HHW system. When the second boiler comes on line the supply temperature to the boilers rises to the level that shuts off the boilers.
I suspect that my boiler pump pressure is over-riding my return pressure from the main HHW pump and short cycling too much hot water. Does this seem like a reasonable assertion or am I missing something?
Re: Decoupler
01/11/2016 3:52 PM
I would need a detailed drawing with temps and pressures to make a guess...It's been my experience that when a system is malfunctioning that there has been a lack of maintenance though....does that sound reasonable?
Good Answers: 137
Re: Decoupler on HHW System
01/12/2016 4:47 AM
It depends on the locations of the pumps and temperature switches (as SE says) and details of how it's controlled. Is "the supply temperature to the boilers" sensed by a switch in the common return pipe?
Register to Reply 2 comments
