Previous in Forum: Subsea Valve Positioner   Next in Forum: Gold particles clogging tubing
Refrigerated Gases
07/27/2007 3:16 PM
I need a good link(s) for finding out as much as I can about refrigerated AR as it would be found in a "dewar" type container. I am able to find bits and pieces but was hoping to find something more informative with no luck...yet.
CR3
Re: Refrigerated Gases
07/28/2007 12:02 PM
"I need a good link(s) for finding out as much as I can about refrigerated AR as it would be found in a "dewar" type container. I am able to find bits and pieces but was hoping to find something more informative with no luck...yet."
Do you have specifics as to the information sought?
Air Products SAFETY GRAM #8 LIQUID ARGON
07/28/2007 3:35 PM
Just needing general basics right now. Temp, volume etc.
What I am looking to do is use it as a cooling system. I am suspecting about 20' 1/8"-3/16" dia tubing coiled around a separate tube (they will share insulation) of greater temp that I wish to cool.
The idea is that by using a flow control I can recirc back into the dewar vessel and have a gradual reduction to effeciencey yet a lenghty lifespan of the cooling system
07/28/2007 4:12 PM
Any particular or compelling reason to use L.Argon? I was under the impression that it was a bit pricey due to rarity. Is temperature critical?
Liquid Nitrogen has better availability and price
Air Products SAFETY DATA SHEET 7 LIQUID NITROGEN
07/28/2007 6:50 PM
Nibbling near my proprietary hedges my fellow. Alas no worries. In fact glad to share.
I want as low an achievable temp as possible that is all. Hydrogen would be great with exception to the Kabang. The thought is that I will be re-introducing the warmer gas to the cooler vessel to achieve a long cooling cycle via m.f.c.
I am sending this response prior to review of your link.
07/28/2007 11:54 PM
CR3: Just now had chance to check bp's and fortunately LN2 boils off at nearly 50 deg colder.
Do you have to replace what I will call the 'process' gas. If so a counter-flow heat exchanger would precool it with the boil off. All depends on volumes etc.
Good luck. SS
07/29/2007 12:20 AM
I am so far over my head I have to proceed. I suspect you might understand.
I am going to do a bit more research and then pose more targeted questions.The project is quite large minded, albeit a small device, and I have more pressing work at hand. This old idea has a habit of popping up now and again and I am at a point where I will be needing expert help (help which I cannot afford presently) but I keep an aye on the lurker all the same.
much obliged,
CR3
Register to Reply 6 comments
You might be interested in: Router Bits, Drill Bits, Laboratory Centrifuges
