hello, i want to know one clarification regarding hydro test " can i apply paint/primer on all welded joint before hydrotest" please give your comments with refrence.
Hello, it is not advisable to apply paint/primer on the welded joints prior to hydro test, because , on application of paint or primer on the welded joint, may not reveal the minute leaks, and also, if any leak is detected, the paint is to be removed throughly for repairs of the joint,which will cost you time , labour, and money.And also the joint repaired, may be not of good quality.
thanks gentlemen for ur positive response.but if u gothrough ASME 31.3 PARA 345.3.1 it is written "all joints may be prime and painted prior to leak testing unless a sensitive leak test is required." can u give some comments on this statement. I will be very thankful for you.
