Previous in Forum: Connecting Two Generators Without Transfer Switch   Next in Forum: Plasma Torches in Anode-Cathode Pairs
Gateway Energy Meters
03/06/2016 10:57 AM
Hi ,
i am confused between gateway energy meters (Dtsd 341) and normal energy meters, if any useful link which can be help me , will be appreciable ,
thanks.
Pathfinder Tags: Energy Meters meters
Re: Gateway Energy Meters
03/06/2016 11:10 AM
What is your confusion? What causes it?
What about it makes you think it is abnormal?
03/06/2016 11:49 AM
confusion is Gateway word . one is energy meters for measuring out going power of power plant form getting signal form CT and PTs and that is gateway energy meters. ?
03/06/2016 12:05 PM
Gateway is a corporation.
Gateway Energy Company LLC
Energy meters measure the amount of power/energy that flows through them.
03/06/2016 12:53 PM
may be you are right ..
check this out
http://www.wasion.com/EN/sxdlb.htm
Good Answers: 804
03/07/2016 10:08 AM
In the world of "smart meters", the term "Gateway" refers to the fact that rather than just recording and transmitting the whole house useage data, the meter can communicate, via line modem technology, with specific appliances WITHIN the house that are "Smart Meter Enabled" so that the utility can look at individual load useage , not just the lump sum total. The meter is then acting as a network gateway for the utility into your home appliances. So for example if you have air conditioning and the utility tells everyone to curtail their A/C use during peak hours, they can tell who cheated and give them a penalty.
At my house now, I signed up for a deal with my utility that allows them to disable my A/C during peak use emergencies since I am usually not home anyway. In exchange for that, I get a lower nighttime rate but if I stay home and override the A/C lockout, they put me at the higher rate for the entire month. That is all enabled by my gateway meter.
03/08/2016 12:36 PM
thansk jraef ,
but what is the yous of that meters in power plant ?
Good Answers: 181
03/08/2016 9:10 AM
http://www.gatewayenergy.co.uk/news/want-your-energy-meter-to-save-you-money
Register to Reply 7 comments
JRaef (1); lyn (2); neduetKK (3); TonyS (1)
