Previous in Forum: Design Strain Relief Mechanisms for 3D Printed Prototypes   Next in Forum: Feedback Re U.S. Pat. 9,052,001
Regarding S 275 JR in API 650
03/15/2016 9:12 AM
Which material in ASTM is equivalent to S275JR grade of steel?
Shall i construct the API 650 tank material as S 275 JR wch is not listed in 4.2.5 of API 650. pls advise.
Pathfinder Tags: S 275 JR
Re: Regarding S 275 JR in API 650
03/15/2016 10:12 AM
ASTM, API.
The easiest way is to put it into a search engine.
try "s275jr ASTM equivalent"
Multiple hits.
Check this answer if it suits you.
03/15/2016 12:24 PM
Search, "ASTM equivalent to S275JR".
Search, " API 650 4.2.5".
When that fails, hire a local tech who knows what he is doing.
Good Answers: 34
03/16/2016 3:22 AM
EN S275JR
DIN ST44-2
NFA E282
BS 43B
IS 2062
ISO Fe430B
ASTM A529
A36 is often used to replace S275JR
WP
03/16/2016 4:18 AM
The one that best fits to S 275 JR is A 36/A 36M ASTM, but also you can use ASTM A 572 G50, providing better mechanical properties and similar welding characteristics. You could also use A 992 but maybe more expensive.
It is quite easy to find A 572 G50 at the same or similar price of A 36.
S 275 JR has an ReH 275 MPa and Rm 410/510 MPa, and A 36 corresponding minimum or range values are 250 and 400 / 550, being for A 572 G50, 345 and 450.
If you want different results, don't do always the same (A. Einstein)
Register to Reply 4 comments
IdeaSmith (1); Javier Aseguinolaza (1); lyn (1); Whitephone (1)
