Previous in Forum: Dynamic Viscosity vs. Kinematic Viscosity   Next in Forum: 4.0L Chrysler Engine Remanufacturing
Measuring Curvature
08/01/2007 4:07 PM
I am trying to measure the curvature of a thin label. I have tried using strain but I cant seem to get the right standard deviation calculation of the samples, which leads me to believe that the way I am measuring the strain is incorrect.
Im pretty sure that using strain isnt the correct way to measure curvature. I dont have any instruments to measure curvature, so is there any impromptu way to measure it?
Pathfinder Tags: curvature film thin
Re: Measuring Curvature
08/01/2007 5:38 PM
Put it on a flat plate and use a vernier gauge to measure how high the centre lifts off the surface?
Can we ask why?
Virtually all thin plastic sheet will have a 'grain' and a curve where it is rolled onto a reel.
I wanted flat sheet to build a variable orifice flap valve...even shim steel was curved.
So I built an automated shim straightener!
Good Answers: 94
08/02/2007 4:53 AM
The most accurate method would be a contact-less system such as laser or optical measuring if you have access to it. If it's a one off check & you don't have such systems, ask some companies in your area. You will find most are happy to help out if they have the right equipment.
Engineering Fields - Automotive Engineering - Auto+Motor=Sport
08/02/2007 8:34 AM
Get some chrome spray paint (the good stuff used in custom automotive) and chrome out that sucker. Then get a laser pointer and a tripod like structure. Put the film on something that you can move in one direction in certain distance increments. Make yourself a screen of some sort where you can project the reflected beam. Scan your film. With the incoming and outgoing beam angles you have the angle of tangency at each point. Get the idea?
This worked 4 me for "scanning" the hull curvature of a RC-boat couple years ago.
Disclaimer: This might not work 4 u. I don't know the dimensions of the object your trying to analyze.
Good luck!
If you can't dig it, get a backhoe!
Register to Reply 3 comments
Faustfix (1); Nigh (1); user-deleted-1105 (1)
You might be interested in: Strain Gauges, Strain Reliefs, Spherometers
