Previous in Forum: Your #1 Job is to Make Your Boss Look Good   Next in Forum: Should Voters in PA Ban Fracking?
15 comments
Analog Modulator for Video Camera?
04/24/2016 5:46 PM
I have a need that I hope one of you can answer. I would like to be able to record a low frequency (sub-audio) signal with my video camera, then recover that signal during playback. I imagine this can be done with some sort of audio modulator / demodulator, simply by AM modulating a sine wave audio source while recording, then detecting and low pass filtering the audio on playback to recover the signal. I'd like to avoid a science project and just buy something meant for this purpose. Any ideas? Surely I'm not the first to have this problem.
Thanks in advance!
Pathfinder Tags: data recording modulation video
Re: analog modulator for video camera?
04/24/2016 6:39 PM
Sub-audio? Less than 10 Hz? So, you want to record and play back a sound or just any old signal?
I'd say that depends on the sensitivity of your camera and whatever you use to reproduce the output of the camera.
free online audio equalizer software download - Softonic
Good Answers: 145
04/24/2016 7:27 PM
More information would be helpful. What is the voltage and drive impedance of the signal. If it is not a problem then what is this signal.
What is the reason you want to use a video camera? This sounds like a traditional A/D record and D/A playback operation. With the information provided the use of a video camera does not make sense.
Re: Analog Modulator for Video Camera?
04/24/2016 9:33 PM
I don't think there is anything available off the shelf, or if it is even possible to recover below 20hz in the infrasound range....but you can take a look at this for inspiration...
http://news.mit.edu/2014/algorithm-recovers-speech-from-vibrations-0804
http://www.ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20080034649.pdf
04/24/2016 10:14 PM
The goal is to record some video of a car while capturing accelerometer data. Then play the video and acceleration back into a simulator where the accelerometer data is converted back into physical motion. The signal is in the 0-100 hz range, 2.5v peak. I can certainly do this by AM modulating a 5khz sine wave and feeding that into the mic input of the camera, and on playback amplify, rectify and low pass filter the camera audio output. I'm just curious if anyone has an OTS solution.
Good Answers: 444
04/24/2016 11:43 PM
You're probably better off using a modulated carrier, though I think 5kHz is a bit high. The problem is that you don't know the characteristics of the camcorder's audio circuitry, its frequency response, cutoff frequencies, etc., especially as you get to zero Hz where there's probably a blocking capacitor that will integrate the signal and cause nonlinearities.
04/25/2016 8:50 AM
5 KHz is just a for instance. And the fact that I don't know the characteristics of the camcorder's audio circuitry is why I'm hoping someone has solved this problem already. Zero Hz shouldn't be a problem with an amplitude modulated signal.
04/25/2016 8:16 AM
Can't you create a video of the accelerometer data with an old silly scope?
An oscilloscope built into the dash would be nice.
04/25/2016 10:52 AM
I don't want to make a video of the accelerometer data, I want to record video of the car driving, and record accelerometer data at the same time, so I can play them back together.
04/25/2016 11:23 AM
United States - Member - New Member Hobbies - HAM Radio - AC9JZ extra
04/25/2016 2:43 PM
It seems like you are only interested in the video, and the data, and not audio record/playback. (Most newer recorders can record 2 channel audio).
Why not use a voltage to frequency converter and record that audio. During playback you would use a frequency to voltage converter.
The only dumb question is the one you didn't ask.
04/25/2016 2:59 PM
That would work fine. I'm just trying to avoid "me" doing any of it. I was hoping someone sold a little box that connected to a video camera and I could buy it and be done. Maybe there's an unfilled market niche here.
04/25/2016 3:18 PM
Try Google, "voltage to frequency converters."
http://www.ebay.com/itm/like/261530335132?lpid=82&chn=ps&ul_noapp=true
04/25/2016 3:43 PM
Thanks, that looks like just the thing.
Good Answers: 32
04/25/2016 10:26 PM
Just check that the input frequency response will handle 100Hz.
You might have to ask the seller.
johny451
04/26/2016 10:10 AM
Yeah, I'm not having much luck getting detailed specs. They're cheap enough that I'll probably just buy some and then look up the parts.
Register to Reply 15 comments
bhankiii (6); BruceFlorida (1); JE in Chicago (1); Johny451 (1); lyn (1); Mike Proctor (2); RAMConsult (1); SolarEagle (2)
