What are the Basic fundamental Design equation's or formulae's for the design of Eductor's used to pressurise air with water jet. ? Thanks in advance for your answer's.
Take a pipe. Make a (smooth) restriction inside (e.g. turn a solid plug with a hole in the middle and push this into the pipe) drill a hole into the restriction through the side, push a small stub of pipe into this.
Let water flow through the main pipe. Attach a U tube manometer to the small stub of pipe and see if you have any suction.
It's called having a play to see what happens.
Chose you start point from any constaints which exist for your application .
Alternatively buy a cheap one..there are many very cheap ones designed for mixing cleaning products into water for floor scrubbing machines and such like. Take it to pieces...improve it/modify it to suit your application.
NOTE:- Hard water will fur up the jets of these things...
