Previous in Forum: Calculate Pressure Differential   Next in Forum: Heat Exchanger Failure - Need Help
Loading Units For High Density Building
08/31/2016 4:45 AM
Loading units has its limit at 8000 units. For a high density condominium where the loading units are more than 8000, what would be the proper method to obtain the respective probable flow ? Please advise. Thanks
Pathfinder Tags: design flow loading unit
Re: loading units for high density building
08/31/2016 5:41 AM
Re: Loading Units For High Density Building
08/31/2016 3:26 PM
You seem to be suffering from IC (information constipation), Ethel.
Good moaning!
08/31/2016 3:44 PM
Modified Hunter curve....
Register to Reply 3 comments
Crabtree (1); lyn (1); SolarEagle (1)
