Previous in Forum: Why Ketchup Is Hard to Pour   Next in Forum: Differential Power Supply?
Good Answers: 70
Dayton Vertical Band Saw Model #3Z981
12/23/2016 10:02 PM
To start with, Happy Holidays to All!
Here's my delima, I picked a Dayton 14" wood/metal vertical band saw (model 3Z981) for cheap but I need 2 parts for it. (1) the front table trunnion and (2) the sliding upper wheel hinge/ blade tensioner bracket. Out of frustration, I call Dayton Electric Manufacturing today, talked to their parts department, which passed me to their tech. support, they emailed me an exploded parts diagram for a Dayton model 4YG31 horizontal band saw, which isn't close! I've also checked on Ebay and Amazon but nobody shows dimensions of their parts
So, does anybody have an insight or know of any saw shops that might have these parts "rat holed" and collecting dust?
Pathfinder Tags: Band saws
Re: Dayton vertical band saw model # 3Z981
12/23/2016 10:30 PM
Good Answers: 70
12/24/2016 2:28 PM
Thanks SE, those are the parts. After digging thru ebay I did find a pair of table trunnions for $30.00, they don't have the miter gauge but that's easy enough to plot.
As far as the sliding upper wheel hinge/ blade tensioner, I'm going to do as Del suggests and manufacture my own out of steel. Can't believe they would use cheap cast aluminum for parts that are under the stress the tensioner is. Thanks again,
Dan
12/26/2016 10:12 AM
Building up something? huh, dj?
Good Answers: 70
12/27/2016 7:17 PM
Correct me if I'm wrong, but you seem to be one of the many Troll's lurking here on CR4! Have a nice day, now go away, Please!
12/24/2016 4:37 AM
Sorry, I got no practical help, but it sounds like you have a great project for the holidays.
The top adjuster on my BAS 315 is made from sheet steel, I'm sure it wouldn't be too hard to fabricte something to do the job.
Good luck and suitable festive good wishes!
Good Answers: 70
12/24/2016 2:44 PM
Thanks Del, it's turned into a project for sure. I only paid $40.00 (US) dollars for it, so I can put some money it
I've was toying with the idea of making a tensioner bracket out steel and you clinched for me. I've been able to piece the old one back together enough to cut the material for it's replacement. Otherwise, the saw is in good shape, all the bearing are quite and smooth, And, It even has new tyres on it!
Cheers,
Dan
Register to Reply 6 comments
dj95401 (3); gutmonarch (1); SolarEagle (1); user-deleted-1105 (1)
