Previous in Forum: NGC 5907 ULX is the Brightest Pulsar Ever Observed   Next in Forum: Aluminum Bronze Ams 4635 Bearing Allowable
Natural Frequency For Torsional Vibration
03/05/2017 3:35 PM
Hi All:
I am trying to calculate natural frequency for torsional vibration of fixed fixed beam using following formula in US system.
=1/2*3.142 sqrt(K*g/mr^2) hz
Where K=J*G/L
and G=Modulus of rigidity
g=acceleration due to gravity=386.4 in/se2
m=mass hanging on the beam at distance 'r' from the longitudenal axis
My question is how does the equation above (if its right) is affected if I change the beam from fixed fixed to fixed -free.
thanks
Re: natural frequency for torsional vibration
03/05/2017 4:15 PM
03/05/2017 4:35 PM
Hi thanks for the reply. But the website you pointed has equation for torsional vibration of shaft for cantiliver only. What about ifs its fixed fixed or simple -fixed for torsion (not bending which website has equations)
03/05/2017 5:02 PM
03/05/2017 4:30 PM
Right off the top of my head, I would say that going from fixed-fixed to fixed-free would halve the restoring force so the frequency would be reduced to a factor 1/sqrt(2) or about 0.707.
03/05/2017 4:41 PM
Hi:
I am not getting how it will reduce by .707, because per my equation stiffness, K
K=J*G/L and this does not change based on support system (fixed-fixed pt fixed -free).
thanks
03/05/2017 10:21 PM
My thought was if both ends were clamped, that the stiffness would be twice as much as if one end were clamped and the other free. The stiffness constant, K, is under the square root in the formula for frequency, which is where the sqrt(1/2) = .707 came from.
Maybe another way of looking at it is that a beam clamped at one end would be equivalent to a beam twice as long clamped at both ends.
03/05/2017 4:47 PM
This might help:
http://www.sciencedirect.com/science/article/pii/S0038080614001310
Table 1.
Effects of rotator (ψR) and torsional (ψT) inertias on frequency parameter Ωi of beams with different end constraints.
End constraintSwitch parameter
Frequency parameter
Ωi a and b
ψR
ψT
i=1
i=2
i=3
i=4
i=5
Free–free00–0.64230.65140.9098–
10–0.64230.64550.8924–
11
0.5774
0.64230.64550.8924
1.6317
Free–hinged000.64550.7839–1.5254–
100.64470.7755–1.4885–
110.64470.7755
0.9569
1.4885
2.3608
Free–clamped000.65320.9027–1.8175–
100.65190.8915–1.7716–
110.65190.8915
0.9569
1.7716
2.3608
Hinged–hinged000.70721.2738–2.4296–
100.70441.2566–2.3695–
110.70441.2566
1.6317
2.3695
3.1063
Hinged–clamped000.78391.5254–2.8086–
100.78041.5040–2.7398–
110.78041.5040
1.6317
2.7398
3.1063
Clamped–clamped000.9098–1.8166–3.2192
100.9057–1.7908–3.1427
110.9057
1.6317
1.7908
3.1063
3.1427
a
Results for a=0.2, t=0.1, s=0.43, Kw=500 and Ks=0.5.
b
Bold letters indicate the frequency parameters of beams vibrating in torsional mode.
harrai (2); Rixter (3); SolarEagle (2)
