Previous in Forum: Ozone V ORP Chart   Next in Forum: Thermal and Electrical Effects of Anodizing
thin rubber sheet
08/15/2007 11:10 AM
i am looking for a synthetic blended ,effectively thin (to the thickness of baloon rubber)rubber material which can be sealed to salt water proofing and can be glued to neoprene?..please help
Re: thin rubber sheet
08/15/2007 9:47 PM
Latex can be glued to neoprene, in more than one way
08/15/2007 11:38 PM
Check your public library or university library for a copy.
Might google for thin rubber, latex. or silicone gasket material.
08/16/2007 10:29 AM
You have quite a few options. However, can you be more specific on size, application, equipment, what are you trying to seal exactly? This will help narrow things down quite a bit.
08/16/2007 4:23 PM
Consider SPRAYING the sealant onto the neoprene.
The purpose of a system, is what it does.
08/17/2007 4:28 AM
Pl take Neoprene Adhesive which is available in market and spray it over the surface required .Pl give application so that we can give better advice.
Anonymous Poster (3); hioptemp (1); Stirling Stan (1)
You might be interested in: Rubber Tubing, Thin Film Materials
